Results 1 to 3 of 3
Thread: Champ 5F1 Build
    Dec 2008
    49
    Champ 5F1 Build
    I stripped an old console radio chassis and want to build a Champ 5F1 amp. The power supply came from a 6V6 system and I need help with the wire color code. I have
    1-blue
    1-white/red
    2-green
    2-yellow
    2-red
    2-black which I know are the AC in ( is this considered the primaries)?
    I think the 2-yellow go to 2 & 8 on the retifier (5Y3)
    I think the 2-red go to 4 & 6 on the rectifier also
    What voltages should I get from the different colored wires? Any advice?
    Thanks!!
    Supporting Member Dave Curtis, dB AudioTech's Avatar
    Jun 2007
    USA
    403
    Quote Originally Posted by Rayme View Post
    1-blue
    1-white/red
    2-green
    2-yellow
    2-red
    Thanks!!
    Do you have an ohmeter? I can guess, but guesses are best left confirmed.
    The 2 greens are likely each end of the secondary winding for the 6.3vac filament supply. They should read continuity only between themselves (low ohms).
    The two yellows are likely each end of the secondary winding for the 5vac rectifier filament supply (assuming 5y3 type), and should read as above.
    The 2 blacks are each end of the primary winding. They should read as above.
    The 2 reds are likely each end of the HVac secondary winding.
    The red/white is likely the HV secondary center tap.
    The blue is likely a bias tap from the HV winding. You can expect readings between any of these, with the highest resistance between the 2 reds. Half of that resistance should be between either red and the red/white. Blue to one red should read lower than blue to red/white or blue to the other red.
    Dec 2008
    49
    Thanks Dave, I do have an ohm meter and with your info I have something to start with. Thanks, Rayme
  1. Champ 5F1 cab -possible to fit a 10" in?
    By The Captain in forum Tweed Builders
    Last Post: 10-31-2010, 07:54 PM
  2. New build 5F1 & AA764 champ, 2 in 1
    By nokaster in forum Tweed Builders
    Last Post: 04-11-2010, 02:21 AM
  3. 5F1 Champ ---- some problems
    By calis in forum Debugging Your Build
    Last Post: 02-19-2009, 09:24 AM
  4. 6V6GT Questions: Fender Champ 5F1
    By adammerah in forum Tubes (Valves)
    Last Post: 11-10-2008, 02:25 PM
  5. troubleshooting problems with DIY champ 5F1
    By mike_mccue in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-07-2007, 05:47 PM
