| | #1 |
| Member Join Date: Nov 2008
| 5e3 eyelet board drill pattern
I wanna try and make my on board anyone know where I can get a scale pattern?
| | #2 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
I make my own eyelet boards by looking at various layout diagrams and sort of guessing the size of the board in relation to the proportions of the chassis and then guessing the proportional spacing of the eyelets that is required to fit the components. No big mystery to it really. All it takes is a bit of slap-dash artistic flair. However, if you need more structure/guidance in your design process, there are some layout dimensions for various AX84 amps on their site .
__________________ Building a better world (one tube amp at a time) |
| | #3 |
| Senior Member Join Date: May 2007 Location: SW Florida
The places for dimensions and layout are TurretBoards.com, Ceriatone.com and the Fender Field Guide. You'll have to figure out the actual drill pattern by hand (or with a drawing program). The easiest way may be to get the first one from TB.com I wouldn''t be surprised if one of the begineer books has the layout in it.
__________________ See the birth of a 2-watt tube guitar amp - the "Dyno Tweed" http://www.naturdoctor.com/Chapters/Amps/DynoTweed.html |
| | #4 |
| Supporting Member Join Date: May 2006 Location: Texas USA
I like to just draw on graph paper. Locate the eyelets on 1/10 inch centers and sketch the components in. Then use a scribe to mark hole centers thru the graph paper into the board and drill.
| | #5 |
| Senior Member Join Date: Dec 2007
Here's Ted Weber's page for board design. He makes it simple for you. You can even select the type of terminals (posts or eyelets). https://taweber.powweb.com/tboard/termboard.htm |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| eyelet board wiring | camnicklaus | Build Your Amp | 6 | 12-30-2008 12:57 AM |
| ways to attach eyelet board to chassis? | kbobb | Tweed Builders | 6 | 09-03-2008 05:53 PM |
| Eyelet board stoopid question | lmolter | Tweed Builders | 8 | 05-31-2008 08:15 PM |
| Bullseye pattern on the Slug? | Edward R | Pickup Makers | 14 | 11-03-2007 10:27 PM |
| turret board vs eyelet board | clintonb | Build Your Amp | 5 | 09-22-2007 07:44 PM |
