| | #1 |
| Senior Member Join Date: Jun 2007
| PI values for Class A push-pull
Can someone provide some info on PI resistor values for a 5E3X2 that I've modded to run in Class A? I have the tubes at 300v on plates and 42ma current. The PI is apparently feeding too much signal into the power amp thus it is still clipping/cutting off.
| | #2 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
Something around 190-200 Plate and 50-55 cathode for the PI, 140 plate for the driver and 110-120 plate for the 1st voltage amplifer stage. If the pre-amp voltages you've got are too high, then up the pre-amp sullpy resistor (try 27k or 33k - instead of 22k) However, I wonder if you have built it to run 300V on the plates, then maybe the pre-amp isn't getting enough power? (- in which case you can reduce the value of the pre-amp supply resistor - try going from 22k to 18k)
__________________ Building a better world (one tube amp at a time) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| 6V6 in Class AB1 push-pull mode | bluefoxicy | Tubes (Valves) | 4 | 09-18-2008 04:41 AM |
| Need help with my LP wiring (push pull) | guitarboyled | Guitar Tech | 2 | 05-29-2008 01:19 PM |
| Building a push-pull - what's different? | bluefoxicy | Theory & Design | 4 | 04-18-2008 11:48 AM |
| Push-Pull in the Preamp? | rajones71 | Theory & Design | 9 | 11-14-2007 05:39 AM |
| parameters for push pull class A output? | swt | Theory & Design | 33 | 04-29-2007 05:16 PM |
