Old 01-21-2009, 08:13 PM   #1
Fender Frontman popping out
I've got a Fender Frontman 25R amp thats having some issues. If driven at moderate levels there is a loud series of pops and static until either the amp is shutdown or smacked. Anyone else have this problem? I'm just curious as to where to start looking. Thanks.
mad_driver2 is offline   Reply With Quote
Old 01-21-2009, 09:10 PM   #2
Amp Kat's Avatar
Sounds like a bad connection and most likely on the filter caps. Mark your connectors and pull the board out then touch up as many if not all of the solder joints. Inspect the input jacks also and see if you can gently wiggle and see a gap in the solder joints. Not a hard amp to take apart. You will have to pull all of the pot knobs and nuts holding them on.
__________________
KB
Amp Kat is offline   Reply With Quote
Fender Frontman 15r Blown Fuse Matty Maintenance, Troubleshooting & Repair 10 07-11-2009 03:23 PM
Fender Frontman GHopson Maintenance, Troubleshooting & Repair 4 01-03-2009 11:52 AM
fender princeton 650 making popping noises iang Maintenance, Troubleshooting & Repair 2 09-16-2008 01:23 AM
Help choose Between Fender Frontman VS Line 6 Spider III klandestino Guitar Amps 3 03-08-2008 07:48 PM
Fender Frontman 15R blown output dowlesm Maintenance, Troubleshooting & Repair 6 01-11-2008 05:28 AM
