Go Back   Music Electronics Forum > Schematic Requests
Old 01-23-2009, 03:12 PM   #1
Unhappy Need Schematic - Boss DD-3 Delay Pedal
My Boss DD-3 quit passing wet and dry signals. No sound out except from the 'direct out' jack. The LED still clicks on and off and the power seemed to be ok. I found +9 Volts off the wall wart and +5 in a few other spots (Though I'm not sure where the regulator is. The chips aren't named in a straightforward way). The power supply diode seems to be doing its job.
After attempting to trace the signal and check the wiring/jacks, I've started to get lost. It's difficult to follow the traces with these tiny surface-mount parts and the jungle of wires piled on top. I'm not even sure which jack is the input and which is direct out at this point. I should've written that down when I started.
Long story short: Does anybody have a schemo out there? I managed to find a DD-2 schematic and that's helped some, but the design seems to have changed. The component numbers are different.
Thanks for reading and I hope one of you can help or offer advice.
RB
Red Barrington is offline   Reply With Quote
Old 01-30-2009, 01:55 PM   #2
Solution
In the interest of sharing info, I'll go ahead and post the fix. I managed to get my hands on a dd-2 schematic which helped immensely. First off, it let me know that I had re-wired the jacks incorrectly after they started breaking off. Oops.
Anyhow, there's a main opamp that buffers the output in and out. It's an LF353. I noticed the first audio out was asymmetrically clipping. At the 2nd audio out, it was practically gone altogether. Further investigation revealed the "1/2 Vcc," was being dragged down to less than a Volt. This Voltage is supposed to sit at 4.5 Volts or Virtual Ground between 0 and +9 VDC.
You can check pins 3 and 5 on this IC to check these Voltages.
The Vcc Voltage only goes a few places, usually through large resistors. The exception is IC1. It is directly connected to pins 3 and 5. I popped out IC1 (the LF353) and the Vcc jumped right back up to 4.5 Volts. Then I put in a new chip and everything's working hunky dory.
I bet this failure will happen to someone else out there since this IC is connect directly to the output. It's susceptible to zaps. And the 1/2Vcc isn't really buffered all that well.
Ok, that's enough for now. Hope this helps somebody out there!
RB
Old 01-30-2009, 02:49 PM   #3
boss schemetic
have you tried "free information society? i found lots of boss related schematics...free!
delb is offline   Reply With Quote
Old 02-01-2009, 10:06 AM   #4
Cool
Boss DD2/3 First Edition Sept. 1986
vintagekiki is offline   Reply With Quote
Old 09-23-2009, 10:04 PM   #5
DD-3 Version 3
Hi,
My DD-3 Version 3 . doesn't power up . nothing. however it is missing IC1. Does anyone know what the IC is?
soundforsound is offline   Reply With Quote
Old 11-05-2009, 07:34 PM   #6
No Output
Red Barrington,
I think I have the exact problem you described, lights up fine, Direct Out works fine, but hooked up to Output and nothing.
You stated "The Vcc Voltage only goes a few places, usually through large resistors. The exception is IC1. It is directly connected to pins 3 and 5. I popped out IC1 (the LF353) and the Vcc jumped right back up to 4.5 Volts. Then I put in a new chip and everything's working hunky dory."
I'm looking at the schematic and it lists IC1 as a 5218, not LF353. Are these interchangable chips, or is there a difference in the schematics?
Thanks for any help.
91lespaul is offline   Reply With Quote
Tags
boss dd-3 delay pedal
Boss DD-3 Delay MSIrepair Guitar Effects 1 03-27-2008 03:02 AM
FS: BOSS DD-5 DD5 DIGITAL DELAY W/ 1-SPOT 9v Power Supply noirengineer Flea Market 0 11-26-2007 05:53 PM
FX Loop problem with delay pedal pedrozepelim Maintenance, Troubleshooting & Repair 1 07-06-2007 03:43 PM
Looking for schematic for Boss GT-6 pedal board Steve A. Guitar Effects 0 05-25-2007 11:23 AM
delay/loop pedal Avrum Guitar Effects 0 08-22-2006 04:28 AM
