Results 1 to 4 of 4
Thread: Peavey TNT 115S Speaker Replacement
    Jan 2009
    2
    How do you remove it without tearing up the hardware on the front of the cab? The back has no screws and does not open. I want to save the trim pieces, as this is owned by the church.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,399
    The grille is held on by a sort of super velcro thing. Get behind an upper corner with a screwdriver and pry it out.
    Sep 2007
    108
    It`s really just a picture frame with grill cloth and some shiny fancy attached metal with usually 4 1X1 super velcro like squares in each backside corner.
    I take a strong thin nail and bend it with pliers, slip it in the corner between the tolex and the grill edge, rotate it 90 degrees so it catches the "picture frame" and give a good pull.
    Screw driver works too.
    Jan 2009
    2
    That was the ticket!
    New Eminence Kappa Pro-15A 15" Cast Frame Driver is on it's way from Parts Express! It'll be in on Friday.
  1. Peavey TNT-100 Repair Problems
    By jrem in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-12-2017, 04:43 AM
  2. Peavey TNT 130
    By Jiri in forum Schematic Requests
    Last Post: 11-12-2008, 10:16 AM
  3. line out for peavey tnt 100
    By kprather57 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-02-2008, 04:29 AM
  4. Old Peavey TNT 100 SS Series Has Low Distorted Output
    By jcollins in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-28-2008, 07:33 AM
  5. Peavey TNT 100 popping.....?
    By StratTone in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-09-2007, 01:45 AM
