Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 01-24-2009, 05:37 PM   #1
TDS
Magic Eye level indicator - where to connect it
The Trace Elliot V8 mk II bass amp has a magic eye indicator to show full power. I would like to include something like this in a 220 watt valve bass amp I am currently based on a Marshall VBA400 but using 4 KT88's.
I do not have a problem with the circuitry for the magic eye (EM84), but what I would like to know is where is the best take-off point: speaker out, PI out, PI in etc. I have schematic for the V8 but I assume there must be a sheet missing as it does not show the magic eye.
Any pointers or advice anyone?
TDS is offline   Reply With Quote
Old 01-27-2009, 01:14 PM   #2
Supporting Member
Steve Conner's Avatar
Speaker output worked fine for me in the past. I used a pot so I could adjust it to have the magic eye just closed at full unclipped output.
Steve Conner is offline   Reply With Quote
Old 01-27-2009, 09:20 PM   #3
TDS
Thanks for the info Steve. An attenuated signal direct from the output makes sense, especialy on a high power amp where there is plenty of voltage to play with. Since posting, I have also found a low power p/p amp on Steve Bench's site using a magic eye peak indicator. He is only dealing with 2 watts, but that amp attenuates the signal from the anode one of the push-pull output valves.
stdp switch... can I use a stsp and connect the common? Garydean Music Electronics 9 01-13-2009 12:10 AM
Some Eye candy?? NightWinder Pickup Makers 4 08-26-2008 01:38 PM
EM 800 "Magic Eye" tubes AcePepper Theory & Design 3 03-11-2008 07:03 AM
Magic turn number for humbucker PU! fuzzman93 Pickup Makers 23 01-27-2008 10:59 PM
How to connect my Roland Synth? jjj Music Electronics 26 04-12-2007 03:12 AM
