Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 01-25-2009, 06:57 PM   #1
Marshall AVT150H
I was using my marshall amp and suddenly the sound went dead. The power light is still working but absolutely no sound.
I suspect the tube has blown.
Any recommendations on changing the tube, best brand, number of tubes to buy etc.
Thanks.
pjfernan is offline   Reply With Quote
Old 01-25-2009, 07:48 PM   #2
First make sure your speaker and speaker cable are working. Then check your guitar cable and the guitar. Only then should you assume the problem is inside the amp. Assuming the problem is in the amp, my recomendation is to get it to a good repair tech who is familiar with the inherent problems with modern guitar amp construction. You can try replacing the tubes, but the answer to your question about how many can be answered by looking inside the amp and counting how many tubes the amp uses. Be aware that there can be dangerous voltages present in the amp, even when unplugged. If in doubt - find a qualified tech to examine your amp.
RE
Rick Erickson is offline   Reply With Quote
Marshall AVT150H Problems Force3fan Maintenance, Troubleshooting & Repair 9 10-29-2009 04:51 AM
Marshall AVT150H macheted01 Maintenance, Troubleshooting & Repair 11 07-24-2009 05:09 PM
Help on Marshall AVT150H gone bad..please bryanarzaga Maintenance, Troubleshooting & Repair 12 02-28-2009 01:53 AM
Marshall AVT150H in need of some help! Benseven Guitar Amps 1 01-21-2009 08:00 AM
Marshall AVT150H trouble johnewing Maintenance, Troubleshooting & Repair 1 11-03-2008 06:03 AM
