| | #1 |
| Senior Member Join Date: Sep 2006 Location: Englewood, CO
| montgomery Wards gvc-9058A squealing
This is an informational post; I had a Monkey Wards GVC-9058A head in for service. With new 6l6gc's it would squeal like a pig (not a sign wave..more like a pulse). Older Fender type 6l6gc's worked just fine. Perhaps some of you have seen this issue before. This is only the 2nd one of these I have had experience with. Not having the nos to spare for this amp I had to figure out why it was doing this, besides it bugged me that it wouldn't work with any 6l6. If I moved the B+ wires around (yes, just the B+ wires) for the 6l6's, the squeal would change. Bridging the electrolytics had absolutely no effect. Removing all tubes but the driver & outputs still produced the squeal, so it was between the driver & the outputs. Adding snubber caps to the plate load resistors in the inverter stage had a negative effect. Removing the negative feedback had no effect. I finally added output screen limiting resistors of 470 ohms to the 6l6's & voila...no more squeal. Stock this amp apparently does not have the limiting resistors. Apparently some interaction with the output screens & the rest of the circuit...I have theories about it, but if someone can come up with the technical reason this worked...I'm all ears. I thought this might be helpful for others. glen - Mars Amp Repair Last edited by Mars Amp Repair; 11-08-2006 at 10:00 PM. Reason: mistake on model number |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Guitar head squealing at moderate volumes | soccerman58 | Maintenance, Troubleshooting & Repair | 8 | 07-02-2006 09:24 PM |
| Squealing/Overloading MIG50 | Michael Allen | Maintenance, Troubleshooting & Repair | 4 | 06-26-2006 09:37 PM |
