Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Conversions
Old 01-29-2009, 08:11 PM   #1
30 Watt AA964 Princeton-ish Head
Dukane PT, Stromberg-Carlson OT, AES 125C1A choke, Hammond chassis.
Controls are: Vol, Treb, Mid, Bass, and MV.
Rich, creamy mids and gobs of sustain--- fun to play.
I just got a NOS Merit OT yesterday--- 6.6k primaries--- 4,8,16 secondaries--- rated for 34 watts---i have another Dukane PT (same p/n as the one used above--- but NOS and perfect looking gray paint, plastic lead insulation).
This 1st 30 watter is spoken for so i might as well build another for me.
I have more Hammond 16x8x2" chassis on hand--- i might use the mesh cage for this 2nd one instead of the wooden head cab.
Pics of the 1st one:
More Pics: http://s46.photobucket.com/albums/f112/gldtp99/Mule%20P30/
With faceplate/head cab it will look like this one (a Bogen CHB50 i converted to a 5F6-A circuit) but with a black faceplate and chicken head knobs:
I'm also considering removing the MV and putting a tonestack ground-lift boost (footswitchable) in it's place.
Amp are fun...............gldtp99
gldtp99 is offline   Reply With Quote
Old 01-31-2009, 09:48 AM   #2
I removed the Crossline MV and put a Boost in it's place--- a tonestack ground lift-type simple boost, footswitchable.
This has definite possibilities---- it adds quite a bit by itself and works very well with a front-ended OD pedal---i tried a Keeley modded Tubescreamer and an MXR ZW OD and both worked pretty well.
I'm thinking that the boosted tone might benefit from some NFB added back into the amp to decrease bandwidth a little--- there's no NFB now so i'll experiment with NFB amounts to get a balance between Tweed-ish clean tone and the Boost tone being a bit more compressed.
The orig AA964 2.7k NFB resistor allows way too much NFB for my taste.
I like the clean non-boosted tone with no NFB so i'll try and find a happy compromise when i get some more bench time................gldtp99
Building my Park 1210 Head Replica - Cutting list or plans for Marshall MV style head pedrocortez Cabinetry 6 10-02-2009 04:26 PM
Sunn 120 Watt valve head, no sound. What to do? flyingtele Maintenance, Troubleshooting & Repair 6 03-13-2008 12:09 PM
SJB AUDIO VALVE SPECIAL 100 watt head theriffjunkie Guitar Amps 1 11-30-2007 11:43 PM
1966 fender blackface bassman ab165 50 watt head ledzeppelinwasprettygood Vintage Amps 17 02-06-2007 03:18 AM
40ish watt amp through 30 watt speaker, dangerous? tunakdude Theory & Design 6 09-03-2006 05:50 PM
