Go Back   Music Electronics Forum > Amplification > Harp Amps
Old 01-31-2009, 05:38 PM   #1
Switchable b+ power?
What about switch-selectable b+ in my PP 6L6x2 cathode biased paraphase inverter homebuild to make if more versatile for different volume needs? The power tranny has multiple hi V secondaries. Say 6L6 plate voltage of around 390 for louder and 330 for quieter situations? It is now running at about 390 V with a 200 ohm cathode resistor and 50 mfd cap. Do I need to switch in a different cathode resistor value with reduced b+ voltage?
Thanks-
Jim R
chuggy is offline   Reply With Quote
Old 02-01-2009, 04:22 PM   #2
Its safe for the tube to use the same cathode resistor,as long you have a resistor tailored to the highest voltage.
But you aint get the best sound out from it.
You probably get a little earlier breakup, but thats what you want. I dont believe it's gonna be much lower volume.
If you switch to lower voltage, and a 250-270 ohm, cathode resistor and use a pair of 6V6's i believe you get a better solution.
It give a very big volume difference if you use a smaller speaker. I have my ampheads combinated with 2 - 3 different speaker cab combinations. It give me possibility to choose gear after situation.
arnenym is offline   Reply With Quote
Old 02-01-2009, 04:29 PM   #3
bnwitt's Avatar
You'll need to change the bias supply voltage as well along with the B+. The Fender Red Knob "The Twin" had a low/hi output switch that did just that. It actually dropped out half of the PT's secondary HT winding and changed B+ to the power tubes from 469 to 236 that way.
bnwitt is offline   Reply With Quote
Old 02-01-2009, 07:22 PM   #4
Thanks for the reply. However, this concern does not pertain to a cathode biased amp (described in initial post).
Jim R
Old 02-02-2009, 05:18 AM   #5
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Quote:
Jim R
Huh? What are you talking about? That is precisely what you described... a cathode biased amp with 6L6s...
"...my PP 6L6x2 cathode biased paraphase inverter homebuild..."
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 02-02-2009, 06:06 AM   #6
Sorry for the murky reply- it was directed at "You'll need to change the bias supply voltage as well along with the B+." This does not pertain to a cathode biased amp since it does not employ a negative bias supply voltage, unless switching in a different cathode resistance is also considered changing the bias supply voltage.
Jim R
Old 02-02-2009, 10:43 AM   #7
You shouldn't HAVE to go lower than 200ohms at anything over 300v (plate to ground)...but your plate current will drop some, so you may want to correct for tonal reasons? Old Dano/Silvertone/Wards used to run 6L6 at just over 300v with an effective cathode value of 180-ish ohms.
MWJB is offline   Reply With Quote
Switchable Bass Boost for JCM900 Dual Reverb tattybob Mods & Tweeks 1 12-17-2008 03:29 PM
Switchable 5F6a/JMP50 jrwalsh33 Build Your Amp 21 09-30-2008 03:23 PM
Master volume - switchable txstrat Theory & Design 8 03-13-2008 01:36 AM
interesting low-power beam power tube- 5686 imaradiostar Theory & Design 5 02-19-2008 09:58 PM
switchable tone stack settings sans pots ? walkman Theory & Design 4 06-29-2007 09:46 AM
