| | #1 |
| Member Join Date: Jan 2009
| How to lessen bass response in tube amp?
This is unrelated to my last thread but pertains to the same amp - a Koch Powertone II. This amp puts out a LOT of bass even with the bass control turned all the way down. Its bass response makes playing with neck position humbucker difficult because the overpowering bass causes a somewhat rubbery sound. I have a schematic if anyone is interested. thanks, brian |
| | #2 |
| Senior Member Join Date: Apr 2007 Location: sydney australia
a schematic would help. im unfamilar with the amp, so i cant help without it. if its a combo it could be partially due to the speaker/speakerenclosure |
| | #3 |
Here is the schematic: www.guitar-dreams.com/misc/KochPowertoneII.pdf I don't think it is a speaker cab issue because my other tube amps don't sound nearly as bassy. thanks, brian |
| | #4 |
Any channel in particular too bassy, or all of them? Does the damping switch help (try ultra low compared to high)? |
| | #5 |
It is mainly the two gain channels where I notice the bass. The dampen settings do help somewhat. But they seem to alter the total frequency response versus affecting just the bass. brian |
| | #6 |
| Lifetime Member Join Date: May 2006
Cut one or more of C5, 8, 10, 14 and 17 in half. If that's not enough, cut them in half again a time or two. At some point, you'll start getting less bass.
| | #7 |
| Senior Member Join Date: Jul 2006
and/or C1 and C6 could be 5 uF (vs. 4x that amount). Every clean channel I do now gets this treatment, thanks Howard.
| | #8 |
| Senior Member Join Date: Sep 2006 Location: Newcastle (UK)
I can't help thinking that the 470pF caps to ground (C9 and C16) may be dulling the amp's tone - sniping these out will increase treble and have the effect of less bass. You could of course just half the value of these caps and see if thats enough. also, +1 on suggestions above - that 22uF cap on the cathode of the first stage won't be helping, try these too... * C1 from 22uF to 1uF (less bass/tighter bass) * C8, C10, C17 from 47nF to 22nF (less bass) * try a 470pF cap accross R28 for more bite in the hi-mids * C41, C42, C43, C44 from 47nF to 22nF (less bass)
__________________ HTH - Heavier Than Hell |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| How about bass tube amp | kldguitar | Other Amps | 36 | 07-06-2009 08:59 PM |
| B&K Tube Tester & output tube question | Chevy | Maintenance, Troubleshooting & Repair | 8 | 12-13-2008 01:08 PM |
| Bass amps w/ preamp tube | lowell | Theory & Design | 8 | 03-24-2008 09:44 PM |
| bass response and coil mismatch.... | Possum | Pickup Makers | 30 | 01-13-2008 09:19 PM |
| Tweaking Blues Deville Bass Response | slapbackdaddy | Maintenance, Troubleshooting & Repair | 3 | 09-26-2007 12:52 PM |
