| | #1 |
| Senior Member Join Date: Jul 2006
| Crossover Fuse Limiter Bulb
could a 3AG 2 amp fast blow fuse be substituted for one of these.....? http://www.speakerrepair.com/Merchan...Category_Code= |
| | #2 |
| Senior Member Join Date: Mar 2007 Location: Philadelphia suburbs
No. A fuse is designed to just blow, not glow. It is the glowing action that makes it work as a limiter. As the bulb turns on it heats the element, the heating then increases the resistance of the wire. The increased resistance forms a voltage divider with the impedance of the driver & reduces voltage drive to the HF. A fuse will just heat up with no glow and then suddenly blow. A lot of speaker manufacturers use 12volt automotive bulbs (although there are better, more linear choices). Get a few different 12V automotive bulbs and use whichever one seems to work the best. The "bulbs" used by professional speaker manufacturers are almost always 12v at anywhere from 0.3-2amps of current capacity. A 0.5 amp or so auto bulb ought to protect a low power HF. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Univibe \ NeoVibe question: Bulb not flashing | greg | Guitar Effects | 3 | 03-15-2009 06:19 PM |
| crossover help | mbailey | Maintenance, Troubleshooting & Repair | 4 | 11-10-2008 09:34 PM |
| Pilot light bulb equivalents? | CitizenCain | Maintenance, Troubleshooting & Repair | 6 | 06-30-2008 05:29 PM |
| Mesa Boogie SOB limiter control | lowell | Guitar Amps | 2 | 11-30-2007 10:05 AM |
| Bulb v.s. Variac | Andy S. | Maintenance, Troubleshooting & Repair | 7 | 11-26-2007 09:23 PM |
