| | #1 |
| Senior Member Join Date: Feb 2007
| Learning the LCR Meter
I just bought my first LCR Meter on Ebay. It seems pretty decent for less than $50. It's a no name LCR4070. I've been winding pickups long enough now to get one in order to make them more consistent I hope. Anyway, I was taking some readings and comparing to different brands of similar designed pickups I have in the shop, Duncans, Fender, Suhr, etc and I got different readings but I don't quite understand them all. I set the meter to 20H to read inductance and I get these readings, (I won't disclose the actual model in case they get mad) Duncan Strat = 6.37H Suhr Strat = 7.19H My Pickup = 5.91H I set the meter to 20nf to read capacitance and I get these readings, Duncan Strat = 8.77nf Suhr Strat = 7.37nf My Pickup = 7.19nf I understand the capacitance reading (I think) but what do the inductance readings tell me? I assume these represent actual Henries but they seem kinda high. FYI the back of the box for the Custom Shop Fender 69 Strat pickups say they are 2.2 Henries and I got almost 6H on my meter. False advertising? Or does it really matter if it sounds good, just keep the numbers in range? Thanks |
| | #2 |
| Senior Member Join Date: Sep 2008
Do you know what frequency your LCR meter is testing with? Inductance and capacitance will be different when tested at different frequecies. More expensive LCR meters have multiple test frequencies... For instance the extech can measure using a test freq of 120hz and 1khz...
| | #3 |
| Supporting Member Join Date: Sep 2007
Low Q (high loss) inductors are hard to measure. It is unlikely that a no name meter does it right.
| | #4 |
On the 20H setting it measures at 100Hz On the 20nf it measures at 1kHz |
| | #5 |
This is the one I got if that helps. http://cgi.ebay.com/3-1-2-bridge-LCR...3%3A1|294%3A50 |
| | #6 | |
| Supporting Member Join Date: Jul 2008
| Quote:
With inductance you're going to see less dramatic changes with the actual windings. Inductance really starts changing when you start mucking with the metals. For example in a humbucker your inductance can change dramatically by swapping out one set of pole screws for another, or changing the keeper bar to a different alloy. Just so you can see a different im sitting here with one of my humbuckers and the extect meter that many people here recommend... Here are the three main items at two frequencies Inductance (Series) @ 120hz = 4.38H Capacitance (series) @ 120hz = 384.2nf AC Resistance @ 120hz = 7.84 Kohms Inductance (series) @ 1khz = 4.085H Capacitance (series) @ 1khz = 6.158 nf AC Resistance @ 1khz = 11.367 Kohms The DC Resistance is 7.79 . Look at the difference in the capacitance at the two measurements.. If I remember correctly, both the inductance and capacitance will continue to drop until you hit the resonance peak frequency of the pickup. Im hoping joe or one of the electrical wizards pipes up and fixes my statement as i've just started learning about this stuff and have been piecing it together myself. I look forward to being shown the errors of my ways. b. | |
| | #7 |
| Senior Member Join Date: Oct 2008 Location: Victoria, BC Canada
would this unit serve as a less expensive substitute for the Extech for reading pickups?
| | #8 | |
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Emulating a fancy LCR meter | Joe Gwinn | Pickup Makers | 50 | 12-03-2008 03:57 AM |
| Learning LT Spice | lowell | Theory & Design | 9 | 11-21-2008 11:11 AM |
| Advice for learning | jeremymiller | Maintenance, Troubleshooting & Repair | 6 | 10-02-2008 02:01 AM |
| Determining a short with an LCR meter | kevinT | Pickup Makers | 20 | 12-12-2007 03:46 PM |
| BK Precision Model 879 LCR Meter | Joe Gwinn | Pickup Makers | 0 | 05-26-2007 10:40 PM |
