Old 02-06-2009, 03:19 AM   #1
Fender Blues Junior Power Problem Help
Briefly; Turned on the power switch on my Blues Jr and the on power light indicator doesn't turn on and the tubes don't light up. All fuses appear good. Anybody have any ideas of what I should be looking at to repair this amp?
Thank you in advance. Jack
tubes09 is offline   Reply With Quote
Old 02-06-2009, 03:26 AM   #2
You say "all fuses appear good".Did you check them with a meter? Looks can be deceiving.
stokes is offline   Reply With Quote
Old 02-06-2009, 04:11 AM   #3
Fender Blues Junior Power Problem.
I'll replace the two fuses just to make sure. I want to add that although the light indicator doesn't turn on and the tubes don't light up, I can hear a low volume hum like sound,very low, indicating that some power is getting through. But the amp won't power up. Also, I was running a Fulltone OCD pedal with the amp at low volume. Could that (OCD) over loaded something and caused a short? Thank you again. Jack
Old 02-06-2009, 04:38 AM   #4
CharlieP's Avatar
Quote:
You may find other ceramic fuses inside the chassis Too. When was the last time you changed the power tubes? Just a thought.
__________________
CharlieP
Peavey VK 112 2008
Marshall 250 DFX 2007
Met. Red LP Gibson Robot 2008
Faded Cherry LP Gibson 2007
Fender Strat HSS LSR S1 2008 Pearl
Gretsch G5120 2007 Black
CharlieP is offline   Reply With Quote
Old 02-06-2009, 05:45 AM   #5
Always pull fuses and test them with a meter.
If fuses are OK, then we start looking for a bad side on the power switch, wires of the mains wiring, bad power cord, etc etc.
__________________
Enzo is online now   Reply With Quote
Old 02-06-2009, 05:53 AM   #6
Supporting Member
Hi,
according to the symptoms you describe your amp is missing the 6,3VAC for the heaters' supply. The "power on" light ( or LED ) gets its supply from this line ( via a dropper resistor ), and this could be the reason why the light/LED stays off ( unless, of course, it is blown ) together with the tubes. The faint hum you're hearing could be hum from the +B line making it to the speaker through the OT, this indicates that the rest of the amp is getting power, so I'd say the power switch is ( probably ) OK and take a close look at the heaters' power supply area.
Hope this helps
Best regards
Bob
Robert M. Martinelli is offline   Reply With Quote
Old 02-06-2009, 09:53 PM   #7
Problem solved, tested the fuses and the 5amp fuse(small one) was blown.
Interesting, looking at the fuse it appeared intact. Must have fried
at the bottom undetected. The amp is up and running again. Thanks everyone for your help Jack
Old 02-06-2009, 11:45 PM   #8
CharlieP's Avatar
Enzo was right again as usual! It's great to have him around.
__________________
CharlieP
Peavey VK 112 2008
Old 02-07-2009, 09:54 AM   #9
Supporting Member
Quote:
Hi Charlie,
While I completely agree about Enzo, as I'm very grateful to him too, I'd like to point out that I don't feel like my diagnosis was wrong - If you look at my last post, I stated : "according to the symptoms you describe your amp is missing the 6,3VAC for the heaters' supply" - and the 5 Amp fuse actually IS the Heaters Supply fuse.
Well...I guess the most important thing is that Jack managed to fix the amp...
This forum's one of the last good "places" left on Earth IMHO.
Best regards
Bob
Old 02-07-2009, 10:19 AM   #10
txstrat's Avatar
Quote:
Bob, I agree
cheers
Matt
txstrat is online now   Reply With Quote
Old 02-07-2009, 01:49 PM   #11
CharlieP's Avatar
No dis-regard is intended for anyone's input here. I was directing my reply to importance of actually checking fuses by Enzo's experience and yes your reply was on the mark too. I am a newbie at tube amps and have been following several forums which have helped me very much. Fortunately Enzo follows them too, here and in the Peavey forums. Also I know that other forum members have a lot more experience than I have.
__________________
CharlieP
Peavey VK 112 2008
Old 02-09-2009, 02:22 AM   #12
Just want to say again that I got lucky on this one with a blown fuse,
otherwise it may $$$$. Thanks again for all the pro input.
Old 02-09-2009, 06:38 AM   #13
Supporting Member
Hi Again Charlie,
Maybe I owe you an apology, re-reading my post I think I over-reacted.....
when I posted that I had just been robbed the "fruits" of a big project of mine at work ( I guess I'm born in the wrong place for meritocracy to be found ) so I was kinda touchy at that time.
Peace
Bob
Old 02-09-2009, 08:54 AM   #14
Hey Bob, we're all glad you are here. Sometimes I want to emphasize some particular point, so sorry if it seems directed at you, it wasn;t.
__________________
Old 02-09-2009, 09:52 AM   #15
Supporting Member
Enzo,
I felt the need to apologize because, telling the truth, re-reading that post I felt I kinda over-reacted, and I felt bad about it.....
Thanks for your kindness and concern.
Bob
Old 02-09-2009, 02:31 PM   #16
CharlieP's Avatar
Hi Again Charlie,
Peace
Bob
Bob:
We are all going thru some touchy times with the economic situation. I am only getting 2 days a week. Good thing I am drawing a pension too! Your apology is gratefully accepted. I am glad you are here adding to all the knowledge that is in this forum. A thank you for all who are doing so too!
__________________
CharlieP
Peavey VK 112 2008
about blues junior power transformer jordileft Build Your Amp 6 03-13-2009 03:07 AM
Biasing a Fender Blues Junior Question jar0ahr Maintenance, Troubleshooting & Repair 9 02-18-2009 01:25 AM
Fender Blues Junior Harp mods Watto Harp Amps 6 12-25-2008 05:32 PM
how to fix my fender blues junior Bmxbarspin724 Maintenance, Troubleshooting & Repair 1 11-01-2008 08:22 PM
fender blues junior help JC@ Maintenance, Troubleshooting & Repair 4 02-02-2008 05:24 PM
