Old 02-06-2009, 12:35 PM   #1
What is this component?
Hey guys,
I've been slowly working through this amp sketching out a schematic as there is none to be found anywhere.
The tube compliment is:
6SC7
6SF5
6V6GT x 2
5Y3GT
On the 6SF5 there is this little component attached from pin5 (plate) directly to ground, can't be more than 3/8" long, looks like a grease zerk. Black in color with a dab of violet and yellow. Leads come out of the side of the body kinda like an orange drop but definitely not out of the ends.
I can not measure any resistance across it.
Anyone know what this is and its intended purpose?
Thanks
pchilson is offline   Reply With Quote
Old 02-06-2009, 01:26 PM   #2
Supporting Member
Hi,
I think it's a small ( = low capacitance, 4,7 or 47 pf, can't tell for sure from the pics ) capacitor sending the highest frequencies from the plate to GND ( low Xc at high frequencies ) to keep the thing from oscillating.
Hope this helps
Best regards
Bob
Robert M. Martinelli is offline   Reply With Quote
Old 02-06-2009, 02:08 PM   #3
guitician's Avatar
Yep, it's a capacitor. A rare tubular type, and by the Yellow/Violet markings it's value is 47pf.
guitician is offline   Reply With Quote
Old 02-06-2009, 02:15 PM   #4
So, on a recap should this be an included replacement or safe to leave in place?
Any guess to the type? Mica?
Thanks
Old 02-06-2009, 02:35 PM   #5
Supporting Member
gbono's Avatar
Yes it's a "dog bone" tubular ceramic capacitor. I suggest leaving it alone unless you are sure it is defective.
Read about them here - http://www.vishay.com/docs/22019/cergenin.pdf
gbono is offline   Reply With Quote
Old 02-06-2009, 04:09 PM   #6
Mars Amp Repair's Avatar
'Tubular Dogbone' ? Sounds like a farrrrout hip old blues cat from the '70s man ;-] g
Mars Amp Repair is offline   Reply With Quote
Old 02-06-2009, 05:12 PM   #7
basically an obsolete style from what I've seen. Some have less coating and you can see through the tube, while for others the whole body is coated over. There were some new I've seen that had the same shape but they were apparently huge. Some old resistors have the same "dog bone" structure also.
dai h. is offline   Reply With Quote
Old 02-06-2009, 05:28 PM   #8
Supporting Member
gbono's Avatar
Okay, if your going to use Tubular Dogbone for your stage name I get 15%
I have only encountered these in high frequency designs (way above the audio band)..........
Old 02-06-2009, 07:54 PM   #9
Site Janitor
tboy's Avatar
Quote:
What kind of amp is it (make & model)?
__________________
-tb
tboy is offline   Reply With Quote
Old 02-06-2009, 08:00 PM   #10
Quote:
Its this Newcomb G-12
Old 02-07-2009, 09:40 AM   #11
Supporting Member
Quote:
Me too, as I was saying, its Capacitive Reactance Xc is very low at higher frequencies and very high at audio frequencies: Xc= 1/(2Pi*F*C) so, at 20 KHz its capacitive Reactance is about 170 KOhms, at 20 Hz we have 170 MOhms, while at 20 MHz it's 170 Ohms ( and we're waaaay into the RF "realm" ).
This is why my best guess is that capacitor is there to keep that stage from unwanted oscillation, as it's a route to GND for all the frequencies above the audible range.
Hope this helps
Best regards
Bob
Old 02-07-2009, 02:22 PM   #12
Tubular Dogbone
[QUOTE=gbono;91441]Okay, if your going to use Tubular Dogbone for your stage name I get 15%
component trouble again scole Theory & Design 11 06-02-2008 03:56 PM
mesa component wrong spec? Alex R Maintenance, Troubleshooting & Repair 1 07-17-2007 08:17 PM
More component help! The Captain Guitar Effects 2 06-19-2007 10:31 PM
Again hum and smoke... but from another component slidincharlie (Carlo P) Maintenance, Troubleshooting & Repair 13 03-22-2007 09:34 PM
Component question on Electric Mistress Neal Guitar Effects 7 06-23-2006 06:21 PM
