Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 02-07-2009, 01:28 AM   #1
Draining Filter Cap Question
I understand (from a previous post of mine) a common method involves connecting jumper wire from the chassis to pin 3 of a power tube. Just wondering what type of cable is acceptable and what type of insulation on the cable as well as the alligator clips. I can picture draining these caps generating a lot of heat and want to be absolutely sure that the insulation holds up! Also, would it be worthwhile to connect a power resistor in the middle of the cable? If so, what specs?
I am on the mouser site now ordering parts for a mod that Chuck H recommended me and figure I may as well order parts for the filter cap draining.
thanks,
brian
bhuether is offline   Reply With Quote
Old 02-07-2009, 03:11 AM   #2
defaced's Avatar
Heat is a function of power dissipation, and the filter caps in guitar amps don't store enough current to really produce excessive amounts of heat when draining.
A 220k, 2w resistor will be plenty to drain the caps. I wire them directly across the cap so that they bleed the voltage off when the amps is turned off. These are called bleeder resistors. If you want to do it as a jumper, then normal 300v PVC coated stranded wire will work. I'd use anything between 20 and 18 gauge.
__________________
-Mike
defaced is offline   Reply With Quote
Old 02-07-2009, 06:09 AM   #3
As Defaced said...
FWIW your amp DOES have bleeder resistors in the circuit, and so drains itself whenever it is turned off. Also, your amp does not need to have the standby in the "play" position for this to happen, where some amps do.
The method I described for you is a universal, fool proof method that will keep you from getting shocked no matter what amp you work on. Some seasoned amp techs use this method no matter what they are working on just to be safe because it is repetition of good general safety practices.
If you want to idealize the system a 100k 3 watt resistor in between the alligator clips is a good idea. It slows down the discharge which I suppose is better for the capacitors. And as Defaced said, 20 to 18ga. wire is fine, Just to be on the safe side use 600v insulation of any kind (pvc, silicone, etc.) Use stranded wire. I have a half dozen alligator to alligator leads that I made from broken test leads. Nice and flexible.
Chuck
Chuck H is offline   Reply With Quote
Old 02-19-2009, 03:00 PM   #4
What is the best way to insulate the alligator clips themselves. All I can find locally are all metal clips. Would wrapping them with electrical tape be good enough for draining purposes.
Thanks Rob
Robmosis is offline   Reply With Quote
Old 02-19-2009, 03:30 PM   #5
"I understand (from a previous post of mine) a common method involves connecting jumper wire from the chassis to pin 3 of a power tube." I'm not aware that this is a common method at all - the more common method would be to utilise the dropping resistors in the power supply and clip the jumper to pin 1 or 6 of a 12AX7 style PREAMP tube & wait 30 seconds. Don't need big wire, those bags of insulated jumper leads work fine.
MWJB is offline   Reply With Quote
Old 02-19-2009, 04:14 PM   #6
Sometimes when i'm in a hurry i put screwdriver accross stdby or pwr switch or even caps to ground. Am I damaging caps or something doing this?
billyboy is offline   Reply With Quote
Old 03-01-2009, 03:49 PM   #7
I have a question on this same topic. I was draining the caps on my Blues Junior. After letting them drain for a few minutes, I checked them with my VOM and there was still around 10~20 mV. Is that normal? Would they ever drain to 0?
Thanks,
Boyt
boyt_bpc is offline   Reply With Quote
Old 03-01-2009, 04:22 PM   #8
defaced's Avatar
With infinite time, yes. This is due to the draining and charging properties of an RC pair. Also, that little voltage with your DMM set to the high voltage scale could be error.
This is functionally how a transformer/rectifier arc welder works. Unless you are exceeding some rating of the cap while doing this, you're not going to harm it.
__________________
-Mike
Old 03-01-2009, 04:26 PM   #9
I was getting this with my VOM set on the minimum DC voltage. After letting them drain for a while I deduced that this voltage would remain and that I'd avoid the caps and be fine (I was only working on the tone pot).
Old 03-01-2009, 09:25 PM   #10
A volt or two sitting in a cap offers no danger.
If you short out a cap to drain it, it will tend to recharge itself a little due to "dielectric absorbtion." Furhtermore, that cap is connected to a whole circuit, and there are other capacitances scattered around in it removed by resistances. SO shorting the main cap doesn;t short those other capacitances, it tries to discharge them through those resistances. Remove the shoort from that main cap and the remaining charges scattered about will try to even out by moving some charge back into the main cap.
SO to actually get absolutely every volt out of a power supply can take some time. But it also isn't necessary.
__________________
Old 03-02-2009, 04:20 PM   #11
Some alligator clips are sold with insulated booties. Sometimes the booties are sold as accesories. I think even Radio Shack sells insulated alligator clips but if you have trouble finding them you can order them from Mouser. In the interem you can just use an uninsulated clip to ground, then hold the other end of the lead with a pair of insulates pliers and touch it to the + terminal of a preamp filter for about a minute. Always test voltage AFTER draining the caps. Excess flux or some other grime can sometimes prevent good contact and the caps will not drain.
Chuck
Old 03-05-2009, 03:53 PM   #12
Quote:
Chuck
I've made two cap draining tools. The first has insulated aligator clips on both ends and a 2watt 5k ohm resistor. The second is a test lead form an old VOM that I clipped the banana plug off of and installed an insulated aligator clip. That one is real convenient for getting into the tight places and draining those caps.
Old 03-05-2009, 08:13 PM   #13
I don't know why anyone gets all fancy on this! Plug a cable into the amp, turn it on, hold the plug tip on the other end to make the amp hum loudly and the turn it or at the off switch or unplug it. When the sound dies, the caps are discharged. I always check with my DVM to make sure, but this is what I usually do.
__________________
John R. Frondelli
jrfrond is offline   Reply With Quote
Old 03-05-2009, 09:01 PM   #14
Quote:
That strikes me as a seriously bad idea.
Old 03-06-2009, 07:22 AM   #15
Quote:
OK, I've been doing this for over 30 years. What strikes you as a bad idea? Essentially, you drain the caps through the speaker load. You need to provide a signal in order to help the caps drain faster, so I use the hum from an open cable being held in my hand. It could be from a guitar or signal generator as well. Best of all, it's totally non-invasive and does not require thinking about where to place a bleeder resistor. If the amp, by some chance, will not power up, the caps are probably discharged anyway.
And, like I said, I ALWAYS double-check when I open the amp with my DVM, and you (meaning everybody) should too!
__________________
John R. Frondelli
Old 03-06-2009, 02:43 PM   #16
The reason I said that was because not all amps will drain the caps that way, so it doesn't always work. Not all amps have bleed resistors.
Old 03-06-2009, 03:55 PM   #17
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
I don't think there is anything wrong with John's method either.
I do the same thing with my signal gen when working on my bench.
The real downside is that the tube amp must have hot vacuum tubes in order for them to work and drain off the B+ rail.
If you flip an amp on and off too fast, the rectifier will charge up the hi-voltage caps instantly if solid state (and very quickly with a rectifier tube)... but the other tubes might not heat up and will not conduct!
So then the filter caps do stay charged up and can give you serious poke.
Just respect that and the method John is stating is fine most of the time.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 03-06-2009, 04:41 PM   #18
.....And, like I said, I ALWAYS double-check when I open the amp with my DVM, and you (meaning everybody) should too!
There's a good reason I said this.
Use your head, and you'll get to keep it.
__________________
John R. Frondelli
Old 03-06-2009, 04:56 PM   #19
It sounds like the common knowledge is "It works" but the mantra in learning is "Don't do this."
Old 03-06-2009, 09:41 PM   #20
I've been repairing and building amps, guitars and drums for 30+ years. I'm involved in electronics, woodworking, metalworking, finishing, power tools (some potential very dangerous) and I have made and gotten away with more stupid and dangerous (personally) moves than I care to count. I don't advocate the use of dangerous practices, but every experienced tech does it, and occasionally pays for it (a few with their lives). This is why I recommend the DVM-backup approach to ANY method of cap discharge, whether it is my down & dirty method, or the bleeder resistor approach. I was once on the receiving end of a paramedics' defibrillator paddles from a massive shock when I first started in this business, and now have a healthy respect for electrical current. You should too. THAT is the proper school of thought.
__________________
John R. Frondelli
Old 03-06-2009, 10:40 PM   #21
I am of the belief that, if it can kill you, don't take the shortcut.
Old 03-07-2009, 04:08 AM   #22
The bottom line is we want to empty our caps. Whatever method you chose, if it works and you check with a meter, then IT DOESN'T MATTER WHAT THE METHOD IS. We can endlessly debate whose method is "better," but if it works it works. The fact that someone like John seems comfortable doing it doesn't detract from its efficacy. I may seem nonchalant doing my benchwork as well. Doesn;t mean I am not aware of the safety issues, they are part of my routine. I feel a lot safer relaxed and confident in my approach than being all tense, uptight, and fearful.
__________________
Old 03-07-2009, 03:32 PM   #23
Quote:
Agreed.
Old 06-29-2009, 05:20 PM   #24
when you make your own cap drain tool can you put an LED after the resistor going to ground for visual progress purposes? thanks
chordfinger is offline   Reply With Quote
Ampeg VT22 filter cap question AL30 Maintenance, Troubleshooting & Repair 4 11-24-2008 01:46 PM
Filter Cap Values? michaelj Maintenance, Troubleshooting & Repair 4 07-13-2008 06:43 AM
Filter cap question lowbrow Maintenance, Troubleshooting & Repair 2 05-09-2008 09:00 PM
small-value poly cap in parallel with PS filter cap pvsage Guitar Amps 3 08-28-2007 04:47 PM
Filter cap limit? MikeT Theory & Design 4 12-27-2006 07:41 PM
