Go Back   Music Electronics Forum > Amplification > Guitar Amps > Theory & Design
Old 11-15-2006, 09:36 PM   #1
2 channel single ended
I am thinking about building a 2 channel single ended amp using a power section like
http://annex.ax84.com/cliffc/amps/AX...0Schematic.pdf
For the preamp section I would like to use something like the bassman normal channel. See attachment. I want each channel to have its own vol/treb/bass controls and can only use 2 preamp tubes.
Will I simply be able to tie two of these channels to the grid of the power tube?
This is for a clean sounding amp so I don't need a lot of gain.
Has anyone done this already or know of an example?
Thanks,
Howard
H Chandler is offline   Reply With Quote
Old 11-17-2006, 12:58 AM   #2
Well ...
Come on ya'll. Is this so stupid that you're being polite and refraining from comment? I realize I've oversimplified the question.
Sure, I will have to decouple the stages, and I will probably have to fiddle with the mixing resistor values. So, please don't hesitate to chime in and admonish if this is a totally stupid idea. Will I be able to get enough gain to drive a KT-88. I'm also considering doing a parallel 5881 sort of thing. What do you think? I can take it.
Thanks,
Howard
Old 11-17-2006, 04:16 AM   #3
Senior Hollow State Tech
Bruce / Mission Amps's Avatar
Yes, as long as you keep the two 220K mixing resistors in place and use a .0022uF to .022uF coupling cap in front of the grid of the power tube.
The power tube will need it's own grid load resistor after the coupling cap.
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Bruce / Mission Amps is offline   Reply With Quote
Old 11-18-2006, 02:03 AM   #4
Thanks for the sanity check Bruce. Hows the new digs?
Old 11-18-2006, 09:41 AM   #5
Been a tough move but things are starting to come together.
I pulled out, resorted and put up in bins about 1200 vacuum tubes today and still have a few large boxes with hundreds left to do.
I just got another 20 tweed cabinets in and have about 25 of the 18w and 35w Aurora cabinets due in mid December so I still have some house keeping and cleaning to do.
Bruce
__________________
Bruce
Mission Amps
Denver, CO. 80022
www.missionamps.com
303-955-2412
Old 07-14-2007, 06:50 AM   #6
ever finished?
I would like to see the final schematic of this amp if it was finished. I am thinking of adding a 2nd channel to a vjr.
bsmco is offline   Reply With Quote
DOUBLE Calibrated single coils? ken Pickup Makers 35 10-02-2007 09:55 PM
Mesa Single Rec Issue jak0lantern01 Maintenance, Troubleshooting & Repair 38 12-29-2006 10:53 PM
are single ended ot interleaved?? swt Theory & Design 3 10-10-2006 07:50 PM
single coil magnets in a HB? franklin01 Pickup Makers 8 09-24-2006 02:41 AM
Mesa Single Rec problems iamtheparty Maintenance, Troubleshooting & Repair 2 07-11-2006 07:23 PM
