| | #1 |
| Junior Member Join Date: Feb 2009
| Inductors question
Hi I've an Acoustic 220 bass amp and would appreciate some advice on getting the EQ fully back in action. The 70 and 2000Hz EQ sliders aren't working due to the fact that the inductors for these have been removed by someone who took them to repair something else or use in some other project (as I understand it). Everything's good with the amp, so just needs these replaced and all will be well. I looked through the forums and did find someone giving advice on getting inductors custom made (not an viable option for me just now as funds are very tight). I tracked down a schematic for the amp and looks like originally there was a 93MHY for the 2000Hz and a 3HY for the 70Hz and then I looked on ebay for any possible (cheap) cost effective solution. Problem is my electronics knowledge here would fit on a postage stamp and was bewildered by the variety of high current, low current, bobbin type, radial lead etc etc I'm sorry if this sounds a stupid question but is there any possibility of any advice on which are likely to be the most suitable regarding things such as likely current range I should be looking for in this situation? Looking inside the amp the remaining ones look to be of the bobbin type - is that format relevant for replacement or will other formats do provided they fit? Any advice on what I should be looking for on these type of points and any other things to bear in mind to put me in the right direction would be greatly appreciated. |
| | #2 |
| Senior Member Join Date: Dec 2006 Location: York Pa
A company called Wilco will send you "free" samples - with ~20$ shipping. Alot of people who make clones of Mesa Mark series amps do this.
__________________ -Mike |
| | #3 |
Thanks for the tip Mike (actually I'm in the UK, but I've had a look on their site and found they even send the samples worldwide thankfully). Quite a choice there, but am still a bit unsure which type would suit me best there though, as 93MHY and 3HY is the only info I have for the required inductors and my lack of knowledge on the subject leaves me a bit lost as to probable appropriate current type and physical format. Any guidance? Thanks for your time and trouble. |
| | #4 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
you probably need to take a look at the schematic - The value of the inductor is probably stated on there
__________________ Building a better world (one tube amp at a time) |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Magnet Wire-Making Inductors Q | Chuck H | Theory & Design | 7 | 09-13-2008 06:03 PM |
| Where to buy Inductors? | clintronics | Music Electronics | 3 | 11-04-2007 01:41 PM |
| Power rating for Inductors | Scorpion | Music Electronics | 6 | 07-25-2007 05:10 PM |
| wah inductors | jeff | Guitar Effects | 3 | 02-04-2007 04:20 PM |
| Digitech Bass Synth Wah Inductors | primussy | Guitar Effects | 0 | 11-04-2006 11:53 PM |
