| | #1 |
| Junior Member Join Date: Feb 2009
| tapes for Space Echo
Does this use the same type lubricated tape as the echo plex? I was thinking about buying some in bulk. does anyone sell replace tapes "ready to install"? |
| | #2 |
| Supporting Member Join Date: May 2006
I just saw some on ebay. Do an ebay search for RTL-1. Ready to drop in.
| | #3 |
| Senior Member Join Date: Apr 2008 Location: Oceanside, NY
I haven't used a Roland tape loop in years. Instead, we use 1/4" BASF tape and a splicing block. The tape is much higher quality, and you get a lot of loops out of a single 10-1/2" reel. In fact, I usualy add a couple of feet to cut down on overall wear.
| | #4 |
Can I use the same tape to reload an echoplex catridge?
| | #5 |
Yep! It's just 1/4" tape. You need to cut the existing loop on the intake side, splice in new tape, and run the machine, letting the old tape spill through the pinch roller. When the loop runs completely through and the splice exits the cartridge, cut the tape just past the new splice you made and splice it again to make a loop. On the Roland, you cut the loop to size, run it through and out the tape compartment, put the tape cover back on, and hold the tape straight to let it feed in. Once it's almost all in, you can splice it. This is what I've been doing in our shop for years. Don't waste time or money hunting down old, crappy tape loops. Just go for it with new tape. The bonus is lower noise, higher quality and less head wear and shedding vs. an archaic cartridge. Unless you own a Fulltone Echoplex, you cannot get new tapes. |
| | #6 | |
| Quote:
Should I buy "high" bias or "regular" bias tape? How do these two (high vs regular) differ in operating in tape echo? I remember buying high bias cassette tapes for better sound (I think high bias had more clarity probably on the top end). Would this be beneficial im these type units? | |
| | #7 |
Just scope out Ampex/Quantegy 456, 499, or BASF SM900 and you'll be OK.
| | #8 |
| Junior Member Join Date: Apr 2008
You can find some good ebay sellers of this kind of tapes. Just search for roland space echo and they will appear.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| I fried my Space Echo! Help! | boya | Music Electronics | 0 | 02-13-2008 04:18 PM |
| space echo dying | okayrene | Maintenance, Troubleshooting & Repair | 3 | 11-15-2007 10:06 PM |
| space echo repair....no echo! | bmac | Music Electronics | 6 | 04-07-2007 12:33 AM |
| Roland Space echo | drewl | Maintenance, Troubleshooting & Repair | 8 | 03-31-2007 05:00 PM |
| Roland Space Echo | JC@ | Maintenance, Troubleshooting & Repair | 4 | 06-22-2006 11:34 AM |
