There is a momentary mute as channels switch, that is the job of Q101 and TR105. This is a common feature of most PV amps.
You should be able to control things without the footswitch. But the FS jack does complete the circuits. SO make sure the cutout contacts on the FS jack are making good contact. And check their solder and the ribbon cable.
LinkBack URL
About LinkBacks
