| | #1 |
| Junior Member Join Date: Feb 2009
| Using a Jensen P8R with a Traynor YVC40 - Madness?
I'd like to run a Jensen P8R (rated at 25W rms) out of the speaker cabinet extension of my Traynor YVC40 to help get a punchier top end (and more sound before feedback). But I'm concerned about destroying the speaker as the YYC40 is a 40 watt amp, and the P8R is rated for 25 watts. I'm not concerned about speaker distortion, in fact a bit of controlled speaker distortion is part of what I'm after. Any thoughts?
| | #2 |
I see that my question has basically been answered here Amplifier Power and Speaker Power but if anyone has any thoughts or experience about the specifics, I'd be much obliged. Basically I wanna know if difference between a 40w rms amp and a 25w rms speaker (50w Peak output) is gonna equal some speaker distortion, or a quickly ruined speaker. thanks much, - Adam. |
| | #3 |
| Senior Member Join Date: Mar 2008 Location: Germany
A 40w rms amp might put out over 50w when cranked (40w is the clean power). The peak values for the speakers are the max they can handle in case a 25w rated amp puts out more than that for a very shot amount of time. I wouldn't risk to destroy the speaker and better go for a pair of them or a higher rated speaker. Depending the (good) speaker distortion I think it will start before the speaker reaches it's rms (clean power) value. Last edited by txstrat; 02-15-2009 at 12:29 PM. Reason: added content |
| | #4 |
Thanks for the info! Just to make sure I understand what you're suggesting - If I wire two 25W speakers each rated at 4 Ohms each in series and send signal from a 40W amp that is looking for a 8 Ohm load, I should be good.
| | #5 |
Exactly.
| | #6 |
Fantastic! Can anyone help with resources for DIY cabinet building, or places that sell 2x8 cabs - (I've only seen 1x8s for sale online from easily googled reputable sounding dealers)
| Bookmarks |
| Tags |
| cabinet, extension, speaker |
| Thread Tools | |
| Display Modes | |
| transistor madness | nopainkiller | Music Electronics | 25 | 11-18-2008 08:09 PM |
| Mesa Boogie reverb madness | soberskipper | Maintenance, Troubleshooting & Repair | 1 | 05-24-2008 04:46 AM |
| Jensen MOD 6'' vs Jensen Chicago 6'' | fernando | Build Your Amp | 5 | 03-13-2008 10:20 PM |
| Jensen C12S Impedance? | darrellcheng | Tubes (Valves) | 1 | 03-07-2008 07:13 PM |
| old Jensen/etc. question | Chris - CMW amps | Vintage Amps | 2 | 06-27-2007 02:13 PM |
