| | #1 |
| Junior Member Join Date: Apr 2007
| Allied Knight conversion issue
Hello all, I'm in the process of converting an old 50s Allied Knight amp (with 6v6s power section and 5y3) into a 5E3 circuit, but with a few exceptions: One, its only one channel (only 1/2 of the 12ay7 is being used); two, i opted for a treble/bass tone stack instead of the more typical tweed deluxe setup. Besides this, everything else is wired as a 5E3. My question is this: When its turned on with a guitar plugged in, the volume is adjustable, but relatively low and a really ugly distortion comes out at all volumes. I figured I wired something wrong, but I can't seem to find the problem. Any idea of what's going on? Many thanks for any help you all would be able to provide! |
| | #2 |
| Senior Member Join Date: Nov 2008 Location: Southern California
Matt, do you have a layout as wired that you can share? Barry |
| | #3 |
yes, although I will have to wait until next weekend to post it. Many thanks for your help! -Matt |
| | #4 |
Well, I figured the problem out: loose solder joint. However, now I have another question: When the amp is turned on (with standby switch off) it warms up just like any tube amp should. When the standby switch is turned on, the amp plays and sounds as expected. However, if the amp is on and the standby switch is then turned off (with the amp on), there is a buzzing noise that gradually decreases, but doesn't completely go away. If the standby switch is then turned back on, the amp sounds completely normal with no buzz. I installed the standby before the filter caps, just as it is usually done. Any ideas as to what this is? Thanks for your help! |
| | #5 | |
| Senior Member | Quote:
If it's warmed up and you power off, then power up in standby, does it buzz? What frequency is the buzz; 60 or 120hz? I'd recheck and confirm the wiring/switch/rectifier. | |
| | #6 |
| Senior Member Join Date: Feb 2008 Location: Appleton,Wisconsin
However, now I have another question: Quote: When the amp is turned on (with standby switch off) it warms up just like any tube amp should. When the standby switch is turned on, the amp plays and sounds as expected. However, if the amp is on and the standby switch is then turned off (with the amp on), there is a buzzing noise that gradually decreases, but doesn't completely go away. If the standby switch is then turned back on, the amp sounds completely normal with no buzz. Where do you have the center tap for the ouput transformer connected. If it is at the rectifier move so it is after the switch. I had the same problem that dissapeared after i moved the center tap. Let us know if it works Baddog |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Knight 30watt tube amp | baddog | Conversions | 7 | 11-29-2008 01:10 AM |
| bogen conversion | clayman | Conversions | 8 | 07-16-2008 07:34 PM |
| hi-fi conversion ? | patrick | Conversions | 4 | 05-14-2008 04:43 PM |
| Need info on Knight Model 30-B Tube Amp | bluesman | Conversions | 4 | 04-30-2008 05:21 PM |
| Allied Electronics | Enzo | Music Electronics | 5 | 11-29-2007 03:11 AM |
