Go Back   Music Electronics Forum > Music Electronics
Music Electronics General discussion about music electronics
Old 02-16-2009, 02:24 AM   #1
Organ-mate reverb addition to guitar amp
I have an organ-mate reverb unit salvaged from a Hammond.
http://www.geocities.com/OrganMate/
I'd like to adapt this to a work with a 10 watt tube amp I have. Is this reasonably feasible? Any ideas?
Thanks in advance,
H20rider is offline   Reply With Quote
Old 02-16-2009, 06:35 PM   #2
Seems to me, from looking at the schematic, that you can simply use this the way that an outboard Fender reverb unit is used before an amp. The unit appears to mix dry and wet together near the output, which means it can simply feed an amp input.
The only real shortcoming is that if you intend to blast the front end of your 10W amp and produce distortion, you will also be distorting the reverb sound, which won't sound all that great.
But clean, you should have no problem. Thanks for the schematic!
Mark Hammer is online now   Reply With Quote
Old 02-18-2009, 04:58 PM   #3
I've had one of these floating around with my 'stuff' for years. Dunno if it even works. I have wondered, though, what the advantages/disadvantages are with driving a reverb tank from the cathode of a 12A*7. Could you simply run the cathode bypass cap from a gain stage through the pan input? The fact that You don't see cathode driven reverb circuits that often seems to suggest that somebody smarter than me already figured out which way works best.
Sweetfinger is offline   Reply With Quote
Yorkville Traynor Guitar Mate YGM-1 NoCurfew Maintenance, Troubleshooting & Repair 6 10-19-2009 09:48 PM
Convert Organ Amp to Guitar Amp jeepney Conversions 6 12-30-2008 07:42 PM
baldwin organ amp to guitar amp conversion rochotte Conversions 4 10-26-2008 03:20 AM
Hammond Organ Reverb into Stand Alone Reverb Unit mitz Music Electronics 8 09-25-2008 03:41 AM
Mod'ing organ amp for guitar: Rafael Conversions 15 05-13-2008 04:53 PM
