| | #1 |
| Member Join Date: Oct 2008
| Shieled wires - where should I use them?
Hi! My homemade Super Reverb is pretty quiet, but I'm always looking for ways to improve it. Would shieled wires *somewhere* decrease the (slight) hiss? I don't wanna use the damn thing everywhere, it's such a pity to work with... So far I replaced the wire at the output of the tone stack (from volume pot wiper to next gain stage) whith a shielded one and noticed no improvement. Maybe I could use it elsewhere with more effectiveness? Thanks! Victor |
| | #2 |
| Senior Member Join Date: Mar 2008 Location: Germany
Some use shielded wires from the input to the first stage. That's where the circuit can pick up the most noise.
| | #3 |
| Senior Member Join Date: Aug 2008 Location: Phoenix
Most wires inside a chassis dont need shielding unless it's for protection from coupling to other parts of the circuit to reduce the chance of oscillation. Hiss is from resistors or tubes. Low noise tubes/resistors may help.
| | #4 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
What txstrat said. I always shield the wires from the input(s) to the grid(s) of V1 and then from the 1st vol pot to the grid of the next stage as well. remember to ground the cable shield at one end only (otherwise you'll make unnecessary ground loops). For hiss reduction you can install metal-film plate resistors. However if you are a carbon comp fan, I'd at least keep the plate resistor in the stage before the PI as a CC resistor (as I note that this is where R.G. advocates getting the most benefit out of a CC resistor - and having tried it both ways in several amps for myself, I tend to agree). The other thing about hiss is that if you have a high gain 12AX7 stage with (say) a 220k plate resistor, it will naturally hiss more than a 12AX7 stage with a 100k plate resistor anyway. Higher gain = more hiss (all other things being equal).
__________________ Building a better world (one tube amp at a time) |
| | #5 |
Shielded wire is more to protect you from picking up hum rather than hiss.
| | #6 |
| Supporting Member Join Date: Jun 2008 Location: Italy
If "hiss" is your main concern, then, as already said, you' ll have to look at resistors and tubes, because shielded cable is a countermeasure to reduce hum, not "hiss". Metal film resistors are quieter, but, if we want to further reduce noise, it must also be remembered that most of the noise generated by resistors is thermal noise, the equation for this noise being En=Sqrroot(4KTR) where K is the Boltzmann's constant, T is the resistor's temperature in degrees K, R is the resistor's value and En is ( quite obviously ) the Equivalent noise. We cannot change the Boltzmann constant ( at least in this part of the universe, don't know about how things work in other galaxies ( this trick is rather commonly used in high end hi-fi amps ). So, summing up, to reduce "hiss" you' ll have to use low noise/special quality tubes, and metal film resistors of a higher power rating. Hope this helps best regards Bob |
| | #7 |
Thanks so much for your answers. I had a pretty noticeable hum with the Super Reverb andI couldn't understand why I had that hum since I took special care in the lead dress and grounds positions. I realised the top of the inside of the cab was not covered with conductive tape. Taped it with aluminium and it's totally hum free now. I'm glad it's fixed! Shielded wires couldn't do anything better since it's totally hum free, even with all controls turned all the way up. As for hiss, there's not much of it actually. I used 2W metal film resistors throughout, except for the plates where I sticked with 1/2W Carbon Comp. As RG Keen says, I do find there's a slight difference. Thanks a million again, your opinions are a pleasure to read. |
| | #8 |
| Senior Member Join Date: Dec 2007
| | #9 |
| Senior Member Join Date: Jul 2008
I think what he is saying is his chassis wasn't completely enclosed so it didn't make a good Faraday cage. My bassman hums like a mother with the lid off.
| | #10 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Noisy 'wires' (seriously...) | EFK | Maintenance, Troubleshooting & Repair | 3 | 01-15-2009 07:56 PM |
| shielded wires in 5E3? | kbobb | Tweed Builders | 8 | 09-18-2008 10:05 AM |
| Tied off lead wires? | Dr. Guitar | Pickup Makers | 5 | 12-07-2007 05:05 AM |
| I keep burning plastic covering on the wires! | clintonb | Build Your Amp | 16 | 09-13-2007 11:30 PM |
| Extra PT wires in Mission 5E3 | gtrplr2 | Kit Amps | 6 | 03-18-2007 01:57 AM |
