| | #1 |
| Junior Member Join Date: Aug 2008
| where does distortion come from??
i built a deluxe ab763 with only normal channel(no vibrato no reverb).i cut off the vibrato circuit and vibrato channel preamp circuit. i use 1.5k cathode resistor at 12ax7.less tubes,less current,so the plate voltage of preamp get a bit higher.after trying different value dropping resistors now i get pretty much the same plate voltage as the original schem. problem is there is no distortion (overdrive?) at any volume, only clean. and the tone is dry and hard and bright,bad sound. i tried to bias the 6v6 plate current even more than 30ma, no significant change for the tone. is it just because i delete a channel?? i use hammond ot, jensen c12n,chinese 6v6,should i change some parts? and take ab763 for an example, where does the distortion come from??preamp or pi or poweramp? thanks |
| | #2 |
A good start would be to post the voltages that you actually have at tube plates, screens & cathodes. In reality you might find many Deluxes run over 200vdc on the 12AX7 plates, so how high are your 12AX7 plate voltages? Non reverb Deluxes are not really reknowned for their distorted tone, the additional gain of the reverb is quite desirable for most. You could try a 12AX7 in the PI tube instead of the 12AT7, 820ohm cathode resistor at pin 8 of V1, a larger value NFB resistor (820ohms stock)? |
| | #3 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
Further to what MWJB said, another way of getting distortion (besides from the pre-amp) is by lowering the output stage voltages (to around 340 -350 Plate and 290-300 screens) (try a 5V4 or even a 5Y3GT rectifier) in conjunction with going to cathode bias and biasing your 6V6s to run at max dissipation, and then increase the output of your PI signal. (You should still be able to get some good distortion this way with a 6k6 reflected load). Although you still might have to tweek the pre-amp to get pleasant distortion with all those stages in there
__________________ Building a better world (one tube amp at a time) |
| | #4 | |
thank you MWJB Quote:
now i get B+:400V 6v6 plate current:24.6ma 26.3ma PI 12at7 plate:177V voltage on 470ohm resistor which connected to 12at7 cathode:1.68V preamp 12ax7 plate:165V 12ax7 cathode resistor voltage:1.22V actually i have tried 2 power transformers,the previous one produce too high voltage.i changed it.so i have experienced 12ax7 plate voltage from 165v to about 200V,no big change. yes 820ohm nfb resistor another thing, when i powered the amp,at begining, the plate current of 6v6s are almost the same,they're matched.but several minutes later,one of the tubes get about 7% higher current than the other one.i want to buy a pair of tung sol 6v6 to try.maybe it's all about the tubes?? and if i use 12ax7 for PI,what else parts should i change? | |
| | #5 | |
| Quote:
it sounds like a tweed deluxe.maybe i will try it later. | |
| | #6 |
The additional gain stage following the reverb makes it easier for the amp to distort. 1.68v at the 12AT7 cathode is wrong, you might get that between the cathode and the PI tail resistor (22K), but you should have a lot more voltage than that at pins 3 & 8 of the 12AT7? +/- 5mA is deemed to be a "match", your 7% deviation is what, under 2mA? If so don't worry about it. You don't NEED to change any parts other than the tube itself, when subbing a 12AT7 PI for 12AX7. Though, if you are looking for more drive you could reducethe value of the 22K tail resistor to 10K. |
| | #7 |
In that amp you'll loose a lot of gain thru the tone stack. You could try increasing the value of the mid resistor to reduce the loss of gain in the stack and keep a stronger signal. Try values in the 28k range, maybe work with a 50k pot wired as a variable resistor and play the amp while you make adjustments to the pot. If you find a good setting measure the resistance and replace the pot with a mid resistor of that value. Some folks even lift the ground from the mid resistor which will completely bypass the tone stack. You'll pick up a lot of gain that way, but it may be a little too much. You also might look at reducing the amount of nfb, try a 5k pot in series with the 820ohm nfb resistor and dial in some resistance, that should get you some distortion. And you might try replacing the 12AT7 pi with a 12AX7 to increase the signal level to the power tubes and push them into distortion. |
| | #8 | |
| Quote:
| | #9 | |
| Quote:
i will make some record for it later,maybe you guys can find something out. i have read some thread about the distortion thing on this forum,but i can't understand thoroughly.for the blackface of ab763 schem,does the distortion comes from preamp 12ax7? it doesn't come from PI or power tube,does it? actually i love the clean tone of blackface amp, but my built sounds too clean.it sounds solid state... | |
| | #10 |
"i have read some thread about the distortion thing on this forum,but i can't understand thoroughly.for the blackface of ab763 schem,does the distortion comes from preamp 12ax7? it doesn't come from PI or power tube,does it?" In most successful designs distortion does not come from on, single part in the circuit, preamp and power tubes compliment each other. Most folk sare talking about the reverb channel when discussing AB763. Even so, most guys who want an overdriven sound from an AB763 might stick a tubescreamer in front of the amp. "but my built sounds too clean.it sounds solid state..." This doesn't sound right, did you check out the voltage at the PI cathode? |
| | #11 | ||
| Senior Member Join Date: Mar 2008 Location: Germany
| Quote:
For a drive tone you need to push the power tubes. Quote:
Other way to overdrive the preamp is to add one more gain stage such as in a early 80s Champ II. The 820 ohms nfb resistor might be to small since the amount of signal fed back from the OT lowers the strength of the signal and therefore cleans up the amp. | ||
| | #12 |
Pins 3 & 8 of your PI tube are linked by a jumper wire - what is the voltage at these tube pins? It should be much, much higher than 1.68volts. If it is 1.68volts something is miswired.
| | #13 | |
| Quote:
i tried adding a 1m master volume pot as you said,and removed the 220k mixing resistor.i still haven't get the distortion with the pre stage vol cranking up, and the tone get worse.but when i turn up the master vol to max with the pre stage vol at 3 or 4, i get the tone!! nice tone!! now i love the sound,although i still haven't get the distortion.but i guess,as MWJB said,a tubescreamer can solve this problem. voltage now b+ 399V plate current of 6v6 24ma 25.7ma 12at7 plate 169.7v 169.6v cathode 77.4V the other side of the 470ohm resistor 75.7 12ax7 plate 172.8v 173v cathode 1.278v 1.276v thank you guys!! | |
| | #14 |
I think I didn't make myself clear enough. The master volume is not necessary to get the tone you have now (full open it acts like a plain wire in the circuit). If you're looking for more distortion you might like the 6g3 circuit. Heres a thread where you can find some sound clips: http://www.music-electronics-forum.c...ead.php?t=9928 |
| | #15 | |
| Quote:
the max master vol means .047uf cap directly connect to .001uf cap with a 1m resistor to ground.so the 220k resistor between the caps (original ab763 schem) was removed.i don't exactly know why,but it did change the tone to some degree.and the plate voltage adjustment might help a bit. | |
| | #16 |
The biggest difference is the circuit around the first gain stage. 220k plate resistor and (shared for two triodes) a 1.5 k cathode resiistor (double it's value for only one triode) - plus the tone stack, that makes a big difference too. Then you can expect a nice overdrive sound when you turn up the voulme. |
| | #17 |
Regards negative feedback, the 820ohm resistor is only half the picture, the resistor to ground is 47ohms on the ab763 deluxe, whereas its 100ohms on most other ab763 schematics (probably to compensate for the 8ohm ouput of the deluxe compared to the 4ohm output of most other amps). The 100ohms will give less gain than the 47ohms. I much prefer to get rid of that negative feedback loop altogether. Peter. |
| | #18 |
| | #19 |
| Supporting Member Join Date: May 2006 Location: Texas USA
One thing that rarely gets checked is the heater voltage. It's taken for granted on most amps, but with so many companies making transformers these days, you never know unless you actually measure it at each socket. It can make matched tubes unmatched and preamp tubes lifeless. Bad solder joints, wire that's too small, weak tube sockets and distorted waveform coming from the PT can reduce the voltage getting to the tubes. It may go down when the standby is put in play mode (especially with solid state rectification).
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| distortion+ | dazzlindino | Guitar Effects | 6 | 10-05-2009 11:51 PM |
| Distortion in PP vs SE | bluefoxicy | Theory & Design | 6 | 06-13-2008 10:46 PM |
| I need some distortion | Princeton | Guitar Effects | 15 | 06-11-2008 04:19 PM |
| Old DI with Distortion | nwguy | Maintenance, Troubleshooting & Repair | 2 | 07-08-2007 04:27 PM |
| PA Distortion vs Speaker Distortion? | tbryanh | Theory & Design | 2 | 05-27-2007 02:53 PM |
