Results 1 to 2 of 2
Thread: 63 Vibroverb bias vary trem motorboating problem
    Oct 2008
    24
    Hi!
    I have a motorboating with my 63 VV replica's trem.
    It's a "flupflup" pulsating with the trem. It starts when Intensity is set to 4 and increases when turned up, and when Speed is set between 3 and 7.
    Otherwise the trem works fine.
    I replaced the tube, checked my lead dress, and redid the solder joints with no success.
    May you help me pinpoint the problem?
    Thanks!
    Supporting Member txstrat's Avatar
    Mar 2008
    Germany
    1,229
    How hot have you biased it?
    Since the trem changes the bias to the hotter side when engaged, it might be too hot. I would say a slight "flupflup" is normal.
    Just a thought.
    That doesn't explain the behavior of making the unusual sound only between speeds of 3 and 7, though.
  1. Bias-vary trem with cathode bias pwr amp?
    By Groover in forum Theory & Design
    Last Post: 07-03-2009, 11:46 PM
  2. new bf pr trem problem
    By scole in forum Debugging Your Build
    Last Post: 02-03-2009, 06:34 PM
  3. Need Help with a 6G16 63 RI Vibroverb problem
    By Normybaby in forum Debugging Your Build
    Last Post: 01-11-2009, 02:22 AM
  4. 6G16 Vibroverb vibrato problem - red plating tubes!
    By Josh_B in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-30-2008, 12:55 PM
  5. Bias-Vary Trem won't wiggle....
    By DMichel123 in forum Debugging Your Build
    Last Post: 01-27-2007, 08:19 AM
