| | #1 |
| Member Join Date: Jan 2009
| Extra Gain Stage - Tremolo?
Okay so I'm working on an amp that uses a 6SL7 for the first two gain stages and then uses a 12AU7 (mu of 20) as a 3rd gain stage. Since I have an extra triode left over in the 12AU7, I was thinking it would be cool to add a trem to the amp but most trems use the 12AX7 (mu of 100) or at least the 12AT7 (mu of 70). Here's what I was thinking: I'll use a 12AX7 for both the 3rd gain stage and the trem. The trem will get one half of the 12AX7 so I know that'll work. I can use a 13k plate resistor and a 1.5k/25uF RC on the 12AX7 that is being used as the 3rd gain stage it would have the same gain as the 12AU7. Will this work? I used the triode calculator on Adam's Amp page to arrive at the 13k plate load for the 12AX7. http://amps.zugster.net/tools/triode-calculator Will this sound okay to use a 13k plate resistor for the 3rd gain stage? I guess if it comes down to it, I can use a 12AX7 with a split plate load and dial in the amount of gain that way. |
| | #2 |
| Supporting Member Join Date: May 2006 Location: Texas USA
The gain may be the same, but you won't have the ability to make a very big signal. To make the 12AX7 mimic the 12AU7, you need something like 4.7K in the cathode. Make the circuit look like the Concertina phase inverter in a 5E3 except use a 4.7K on the ground side and 100K on the plate side in place of the 56K resistors. Keep the 1.5K cathode bias resistor. You'll need a cap on the input to isolate the DC if you are coming from a volume control or tone stack or other ground referenced signal.
| | #3 |
Something like this |
| | #4 |
Very cool! Thanks! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| extra long jazzmaster like tremolo arm | Bmxbarspin724 | Guitar Tech | 0 | 11-13-2008 03:46 AM |
| 2203 with extra gain stage - still have a spare triode, what to do? | HTH | Theory & Design | 14 | 04-01-2008 10:08 PM |
| Adding an extra gain stage | EETStudent | Build Your Amp | 1 | 03-18-2008 12:38 PM |
| Problems with extra gain stage in 2203 | HTH | Theory & Design | 17 | 03-16-2008 04:09 AM |
| Adding an extra gain stage to my Traynor YBA-1 BassMaster? | Humbucker | Guitar Amps | 2 | 06-02-2007 07:14 AM |
