Go Back   Music Electronics Forum > Fun with computers
Fun with computers Computer-related issues, like digital recording and stuff like that.
Old 02-21-2009, 05:49 PM   #1
guitar canceler?
Does anyone know of a multitrack recorder that is able to just cancel out the guitar track of a song. So that I can use them as backing tracks for practicing.
I have these softwares and I don't know if either is capable. if someone knows it would be af great help.
Cubace LE
audacity
Fl Studio 7 fruity loops addition
Robmosis is offline   Reply With Quote
Old 02-21-2009, 06:03 PM   #2
Supporting Member
Steve A.'s Avatar
Cubace LE
audacity
At this time the Jam Vox is considered to be state of the art in terms of cancelling out guitar parts- it is a hardware/software package that sells for around $250 that works only when the hardware box is connected.
I would think that 3rd party developers would be creating plug-ins that handle cancellation of both guitar and vocal parts; you might want to look into that. (I'm not sure what kind of plugin work with your programs- there are several different kinds nowadays.)
Good luck!
Steve Ahola
Steve A. is offline   Reply With Quote
Old 03-03-2009, 06:26 PM   #3
Supporting Member
This sounds like a Vocal Zapper application. The simple op-amp hardware versions rely on the vocal (or guitar) to be in the center of the mix. You could emulate the same thing in your favorite audio editor by inverting one channel and then adding them together. Of course you'd have to start with a stereo file, otherwise the whole thing would cancel if you started with a mono signal and copied it before inverting. Pulling a guitar out of a mix otherwise might be a pretty tricky proposition.
GibsonLover is offline   Reply With Quote
Old 03-03-2009, 07:55 PM   #4
John_H's Avatar
There's a bunch of free tracks here.
John_H is offline   Reply With Quote
Old 04-27-2009, 02:46 AM   #5
Capacitordeath's Avatar
I don't know about canceling guitar tracks, but I have used Guitar Pro, which allows you to shut down specific parts of the downloaded song. The song files are much like MIDI files, and can be exported as such. I've used this program to find songs I like, "turn off" the guitar tracks, export the drums and bass to MIDI, and open in Temper (or another DAW), where I run the drum track through Session Drummer and the bass through a free DSK VST.
Capacitordeath is offline   Reply With Quote
Old 06-21-2009, 12:24 AM   #6
Try the Tascam MP-GT1.You can store up to 240 MP3s. Guitar parts can be slowed down, looped and even eliminated to help you to learn new riffs. Play back MP3s using Variable Speed Audition, which slows down the speed without changing the pitch, and sections can be seamlessly looped while practicing tricky passages. Songs can even be pitched up or down to match the tuning of your guitar, so you don't have to re-tune for every song. It uses a high-speed USB connection to load up MP3s and charge the built-in 9 hour lithium battery.
breeze is offline   Reply With Quote
Old 06-26-2009, 11:39 AM   #7
madialex's Avatar
LOL When you said guitar canceler I thought yep, that's what the wife is for
madialex is offline   Reply With Quote
Old 09-08-2009, 09:25 PM   #8
I have found that cancelation software/hardward usually does a fairly bad job. AS stated before, they work off the premise that what you want cancelled is dead center in the stereo image.
mysticalfairy is offline   Reply With Quote
Old 11-03-2009, 10:57 AM   #9
Music Lover
It might be worth giving Winamp a try, a vocal remover plugin may work well for certain tracks.
PaceMaker - Winamp
Vocal Remover - Winamp
Can't hurt to try, it's free.
S.
P.S. Linzday, I so enjoy your posts.
Sock Puppet is offline   Reply With Quote
Guitar Rigs: Classic Guitar and Amp Combinations tboy Content 0 08-03-2008 10:32 PM
The Complete Guide to Guitar and Amp Maintenance: A Practical Manual for Every Guitar tboy Content 0 08-03-2008 10:32 PM
Guitar Amp to Guitar Amp Conversion BackwardsBoB Conversions 15 05-14-2008 05:58 AM
