Results 1 to 27 of 27
Thread: 2 types of wire in a HB?
    Member paulyy's Avatar
    Feb 2009
    arizona
    47
    Hello everyone. My name is Paul. Iv been wondering if any body has ever tryed two types of coil wire for a humbucker. For example, 42 guage enamel for one coil and 42 formrav for the other coil and has any body tryed useing two different guages. Just wondering.
    Pickup Maker
    Bloomfield, NJ
    10,209
    Quote Originally Posted by paulyy View Post
    DiMarzio had a patent on using two different gauge wires in humbuckers. They do that with the Tone Zone, Air Norton, Evo, etc. The patent is expired now.
    I use that trick on a few of my pickups as well.
    www.sgd-lutherie.com
    www.myspace.com/sgdlutherie
    www.myspace.com/davidschwab
    Feb 2007
    214
    Keep in mind that if you use the exact same wire guage (all things being equal), insulation build, number of turns per layer, tension, etc, and you only choose a different type of insulation (PE, Formvar, etc) there will be no difference in sound. When it comes to the wire, you will only notice a difference when you change insulation build (min vs max) and wire guage. For example, 42 guage formvar with a heavy insulation compared to 42 gauge formvar with single build insulation will sound completely different, and 42 guage single build formvar compared to single build plain enamel (given that the inner and outher diameter are the same) will sound the same. Insulation type has nothing to do with sound. Only the thickness of the insulation.
    Feb 2009
    arizona
    47
    Smile
    Thanks for the info.
    Supporting Member JGundry's Avatar
    Jul 2006
    1,002
    Quote Originally Posted by voodoochild View Post
    If you machine wind the different coatings will guide themselves onto the bobbin differently due to differences in texture and you will hear the difference. Some wire coatings jump around more as the coil builds than others. Especially if the machine is set up to do something other than a perfectly flat coil shape.
    Tone Mechanic
    Dec 2006
    1,086
    Yes. Different insulations and builds, same gauge.
    I assure you that it affects tone.
  7. #7
    Feb 2007
    214
    I am only basing my opinion off of personal experience. For me, insulation has no effect on tone. I used to be convinced it did until I rethough my evaluation. It only does when there is a difference in the thickness of insulation or wire. Maybe I don't have the best ears but I am very certain of this. Don't forget, even a machine wound coil using the same wire, etc, will vary from one coil to the next ever so slightly. There is no such thing as "perfect" consistency even on a machine.
  8. #8
    Jul 2006
    1,002
    I have a machine that gangs 4 bobbins next to each other and you can actually see the difference in wire scatter as they wind when the bobbins are side by side.
  9. #9
    Old Timer Possum's Avatar
    Planet Mongo in the country of PAF
    3,888
    Insulations don't sound the same to me either, the dielectric properties of formvar vs. plain enamel are really noticeable to me. I do alot of prototype pickups in my PAF work and going from single PE to single formvar was noticeable enough for me to not use formvar in PAFs. Formvar was noticeably darker sounding, smoother, PE was more a dry tone, crisper. Seth Lover always said he couldn't hear any difference. Its not a big difference but if you're comparing alot of test pickups against eachother you'll hear it eventually.
    http://www.SDpickups.com
    Stephens Design Pickups
  10. #10
    3,888
    Dave do you know the number offhand of one of the DiMarzio patents with different wire, I lost that info somehow...
  11. #11
    Oct 2008
    Burlington, Vermont
    26
    So if I wanted to wind one coil with 42 and one with 43, what would I want to watch to make the two coils balanced as far as humbucking properties? resistance? number of turns? Total area of the wire?
  12. #12
    Tone Mechanic
    Dec 2006
    1,086
    I hear a difference in tone among the insulations. Especially comparing SPN and Plain Enamel. But everyone's ears are different.
    If you do a search there is a thread about this specific issue. From my recollection, Nightwinder did a good description on each that was right on target.
  13. #13
    Pickup Maker
    Bloomfield, NJ
    10,209
    Quote Originally Posted by possum View Post
    dave do you know the number offhand of one of the dimarzio patents with different wire, i lost that info somehow...
    4501185
  14. #14
    Feb 2007
    214
    Quote Originally Posted by Possum View Post
    In my experience with formvar was warmer with less mids compared to plain enamel. The reason I am sure is because the Formvar was heavy build and the PE was single build which makes total sense. In fact most 42 formvar sold is Heavy build and most 42 PE is single build.
  15. #15
    Boston, MA area
    2,117
    Do you know the varnish thickness and copper diameters of the two kinds of wire in question?
    There is a lot of variation in copper diameter from spool to spool, and formvar generally tends to be thicker than plain enamel.
    Formvar is prized for its mechanical strength and resistance to abrasion, making it suitable for winding electric motors, a very severe process.
  16. #16
    Feb 2007
    214
    [QUOTE=
    [/QUOTE]
    Yes this is very true. You can only argue there is no difference between insulations when in fact both spools are identical in copper diameter and insulation thickness. Otherwise you are barking up the wrong tree.
  17. #17
    3,888
    Well if you want to get really nit picky no two spools of wire are identical in any way. I'm talking same build, same O.D., I hear a noticeable difference between formvar and plain enamel. My ears, my experience. If you want to tame some treble in a humbucker use single build formvar instead of PE. thats why I don't use it, especially noticeable in a neck position.
    I don't know how you would even get an accurate measurement of bare wire and insulation thickness without getting some kind of lab equipment. You're talking .00001" differences when you get to insulations, hand held micrometers get real innaccurate at that tiny of a measurement, then there is the problem of how you remove the insulation without taking any of the copper with it? No one has answered that question on this forum so far. So you'd need to contact a lab and probably have a laser device do measurements, maybe a magnet wire manufacturer would be the only place that would know how to do this kind of work. AT a pickup maker's level all one can do is get a vague idea by how easy it is to scrape the wire off, it becomes obvious which wire has a thicker insulation etc. and you just use your ears on the particular wire you're working with.
  18. #18
    Boston, MA area
    2,117
    Well if you want to get really nit picky no two spools of wire are identical in any way. I'm talking same build, same O.D., I hear a noticeable difference between formvar and plain enamel. My ears, my experience. If you want to tame some treble in a humbucker use single build formvar instead of PE. that's why I don't use it, especially noticeable in a neck position.
    I don't doubt that you hear it. The question is what are you hearing.
    I don't know how you would even get an accurate measurement of bare wire and insulation thickness without getting some kind of lab equipment. You're talking .000,01" differences when you get to insulations, hand held micrometers get real inaccurate at that tiny of a measurement,
    You can do 0.000,1" ("tenths") by hand, with care, Wire folk don't try to measure any closer.
    Sure we have. Use methylene-chloride based paint stripper. Or, heat.
    So you'd need to contact a lab and probably have a laser device do measurements, maybe a magnet wire manufacturer would be the only place that would know how to do this kind of work. At a pickup maker's level all one can do is get a vague idea by how easy it is to scrape the wire off, it becomes obvious which wire has a thicker insulation etc. and you just use your ears on the particular wire you're working with.
    Overkill. Just mike the insulated wire, strip the insulation off by fire or chemical, and measure again, all with a micrometer calibrated to tenths.
  19. #19
    3,888
    Well, I am going by actual experience from alot of prototyping, rewinding the same pickup structure with different wire, same number of winds, same winds per layer. I just will not use single build formvar in a humbucker, it sounds good but lacks enough treble bite that plain enamel of the same diameter has. It might be good in a bridge pickup but its a better idea to use the same wire in both pickups, if you make minor changes in one pickup, changes you can't even hear, you will hear it in the middle switch position. Using a dark wire type in the bridge will cloud the middle position more than I like.
    Most formvar is whatever build you order. Most buy the heavy build stuff and never consider the single build. Alot of vintage pickups like the DeArmonds used single build formvar 44 guage, I see alot of this in those types. I was lucky to score a 14 pound spool of that stuff, will probably last a lifetime :-)
    If you don't think insulation type makes a difference just buy the cheap poly coated wire and stick with it. I used to be of the mindset but experience proved otherwise.
  20. #20
    Boston, MA area
    2,117
    The original question was in effect if what you were hearing was due to different insulation type, or due to differences in copper diameter and insulation thickness.
  21. #21
    Jul 2008
    4
    Been grappling with this question on a quest to duplicate some Musicman Sabre guitar low wind pickups. Reading lots of books on the properties of insulating materials:
    1. Handbook of electrical and electronic insulating - W. Tillar Shugg
    and these from a post on Tesla coils
    Dielectric
    1. Polymer Engineering Principles, Richard C. Progelhof and James Throne
    2. Plastics for Electronics, Martin T. Goosey
    3. Handbook of Plastics in Electronics, Dan Grzegorczyk and George Feineman
    4. SPI Plastics Engineering Handbook, Society of the Plasitics Industry
    5. Electrical Engineer's Handbook, Pender - 4th Edition
    6. Phelps-Dodge magnet wire product data
    Here's what I am finding out. Inductance of the pickup forms the high pass filter part of a pickup along with the dc resistance. The low frequencies drop off due to the inductance.
    At the high end, the coil wind-to-wind capacitance causes the high frequencies to drop off. These two effect lead to the resonant frequency that should be characteristic of the tonal quality of a pickup. The referenced books have a lot of info on the various dielectric constants and dissipation factors of the different insulations. Nylon 6/6, for instance has a high dielectric at around 8. Formvar is low, around 2 or 3. A factor of 4x in dielectric should lead to 4x capacitance which should dramatically affect the resonant frequency. I haven't wound enough pickups to know by ear but on paper, this should be a big effect.
    These books also comment on the fact that the dielectric can change over a period of years, mostly dropping, as the insulation ages. Could this be the magical "aged" pickup sound as the capacitance of the coil drops with time and allows a brighter sound? More plausible IMHO than alnico magnet aging. Anyway, the short answer should be "Yes", insulation type should change the sound of a pickup.
    Normally magnet wire is considered "better" with a high dielectric but for pickups, just the opposite may be true. Low dielectric allows a brighter sound.
    Now, Leo Fender was trying to drop the inductance AND the capacitance of a pickup with the Stingray and the Sabre. He wanted to move the resonant peak out to higher frequency. Fewer turns but an active pickup to compensate for the loss in signal. According to UIUC pickup measurements, it worked.
    See
    UIUC Physics 498POM Guitar Pickup Measurements
    The excel file has some great info on pickups. Fender 8KHz, MM Sabre 14KHz. Love to wind some pickups exactly the same with only the insulation change and have Prof Steve E. and his undergrads measure them.
  22. #22
    3,888
    You are forgetting eddy currents, if you are talking humbuckers, this is a critical part of the equation, every alloy has a different effect on tone, and there is alot of metal in a humbucker. In single coils eddy currents happen with alnico and varies by type of alnico.
    As far as "aging" coils getting brighter, its really the other way around, they get darker. But thats not really been proven either, all I can tell you is if you rewind a PAF with modern wire it gets brighter. Some think the copper back then was less pure, but no one has done the lab work to find out. The insulation on plain enamel formula used now isn't the same as used back in old days, formvar is about the same though.
    A good pointer that maybe the old wire was less pure is that I have a '63 early patent, basically its a true PAF but was wound with poly wire, its as dark in the coils as the plain enamel is though not quite as dark. I have early TTops and by then the pickups are just about shrill in comparison to the '63's coils, part of this is the pole screw alloy but everything else is about the same. One could spend alot of money on lab work but what is the point of proving this or that when we can only get wire from very limited sources made in the modern way. No wire maker is going to crank up and produce wire with old time insulation because those old methods were quite toxic compared to today's procedures.
    I was told you could age a coil by using heat, well I tried it and stunk up the whole kitchen, the end result was no change in any of the LCR measurements or ear testing. Smelled good though...
  23. #23
    Jul 2006
    1,002
    If you are talking about vintage era Gibson humbuckers PAf's in a way they do have different coil wire on each bobbin. 50's era plain enamel was not sorted min. nom./nom.-min. as it is now. Plus the build thickness varied more that with T-Top era poly wire. In addition the likelihood is pretty big that the screws cois and slug coils for PAF's were wound from different spools of wire. Put all of that together and you have two different types of wire effectively on both coils. I personally think this wire mismatch is part of PAF tone. By the time you get to T-Top's the poly wire being used is more consistent in size and build thickness than older PE.
    I think the main difference with old PE is the variation in build thickness. The old wire tends to be darker in color and the the darker wire seems to have a thicker build. But even the old wire varies in build. There is one wire company still making wire on par with old PE wire. But most modern PE is made with different enamel formulation and also seems to be more reliable size wise from spool to spool than the old stuff. All of this effect the tone in a humbucker.
  24. #24
    Member mickmutante's Avatar
    Dec 2008
    Bogota D.C./Colombia
    84
    Quote Originally Posted by kevinT View Post
    What about SPN vs. Formvar or PE...??
    I have build some pickups but not as many to hear the differences....
    jairo eduardo suarez gallardo
    mm basses -only exotic woods from Colombia-
    mm basses
  25. #25
    Senior Member LtKojak's Avatar
    Feb 2008
    Milano, Italy
    718
    Quote Originally Posted by JGundry View Post
    Well, all this tends to support my "blasfemic" statement:
    The best PAF p'ups are being produced TODAY, and not by just one but by MANY producers, and not only boutique winders but also mass-producing producers as well.
    Are you with me on this too?
    Pepe aka Lt. Kojak
    Milano, Italy
  26. #26
    Senior Member Chadheckler1's Avatar
    Sep 2008
    108
    Quote Originally Posted by j. pierce View Post
    I think you would match the # of turns to get the best humbucking possible...but you could try +/-1000 turns with respect to the other bobbin if you wanted to try and tweak your tone and still get good humbucking properties. Resistance is not as important as turns. The area of the coil will change the tone but I don't think that it has a large effect on the coils ability to reduce hum (Unless you get crazy with the size)
  27. #27
    2,301
    Anything that changes the dimensions of the coil will change a number of outcomes. The inductance can be different. The cumulative DC resistance can be different if the outside circumference is larger. In that respect, noticeable changes in the insulation thickness can have the same cumulative impact as simply altering the height of the to-be-filled area of the bobbin or coilform, or using the same height/width of bobbin but having the polepieces inserted in a plastic core vs "naked" with the wire snuggled right up against it.
    But note that I said "cumulative". The impact of insulation thickness on coil dimensions/properties of a small number of turns is negligible. So, if I underwind a coil, insulation thickness differences should have less impact than if I overwind it.
    Given that, one might expect that insulation thickness has a very noticeable impact on single-coil pickups with 7500+ turns, even when wound to the same # turns on the same polepieces and bobbin, but much less impact on HB pickups where the total number of turns is often much smaller.
    So, I guess before people get all "wound up" about winding, they should probably consider what sort of pickups they draw their experiences with insulation thickness from. Some may be thinking about contexts where insulation has the least impact, and some thinking about where it has the most.
  1. Toxic wire types?
    By NightWinder in forum Pickup Makers
    Last Post: 02-19-2008, 06:18 PM
  2. weicowire.com and wire types?
    By nickt in forum Pickup Makers
    Last Post: 11-29-2007, 04:16 AM
  3. General guidelines for types of wire used...
    By ZBod in forum Vintage Amps
    Last Post: 04-14-2007, 07:19 PM
  4. types of delay
    By jbmorse02 in forum Guitar Effects
    Last Post: 01-08-2007, 04:19 PM
  5. Alnico types, magnet and wire vendor links
    By DrStrangelove in forum Pickup Makers
    Last Post: 07-05-2006, 11:56 PM
