| | #1 |
| Junior Member Join Date: Nov 2006
| Ampeg BA blowing xistors
A friend of mine has this Ampeg BA115 that is blowing line fuses, and I offered to fix it. I changed out both MOSFET's and the fuse, turned the power on, and the fuse blew. Checking the FET's in the circuit with a DMM revealed that one was shorted. All the zeners check good, and the transistors look good. All this was done with the speaker disconnected. I would appreciate any help or direction.
| | #2 |
| Old Timer Join Date: May 2006 Location: NYC
Although I am not very experienced at solid state circuits,I dont think it is a good idea to run it with the speakers disconnected.When you change the shorted component connect the speakers before testing it.
| | #3 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
If the output has gone to DC, that'll just trash the speaker too, so I'd not recommend it. Solid-state amps are supposed to be OK to test with no speaker, unlike tube amps. However, these circuits can be difficult to troubleshoot without experience. The MOSFETs that Ampeg use (AFAIK) are pretty sensitive to biasing, and vary a lot between batches. Maybe the bias setting that was right for the old set causes the new set to "red plate" |
| | #4 |
| Senior Member Join Date: May 2006 Location: Near Seattle, WA, USA
Most transistor output stages are perfectly stable into no load and that would be my preferred initial check condidtion. Also I strongly recommend you build a "light bulb limiter" to help save those expensive new components and your stock of fuses. A decent explanation of how to build one is contained here: http://www.fenderforum.com/forum.htm...-11-0505:27:17 Some Ampeg MOSFET basics have been covered before, although not for your specific model. Check out these threads with particular attention to Enzo's replies. Ampeg B2 Ampeg B2 - Stopped working. As he says in his comments there can be (and in my experience usually are) other components which have gone bad or been stressed by the initial failure. I've even found driver transistors which checked good in-circuit with simple testing but revealed themselves to have zero beta when checked out-of-circuit on a transistor tester. That's pretty rare (they usually dead short), but it happened to me and cost me a lot of time figuring it out. These days I usually just replace most of the transistors in the amplifier circuit as a precaution after a power transistor failure in an Ampeg solid-state. Like Enzo says - they're cheap... |
| | #5 |
Thanks. And do not assume it is only the transistors. Make sure the rectifiers are OK in the power supply. and the unlikely but possible filter cap short. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| acoustic model 450 blowing fuses | wardevans | Maintenance, Troubleshooting & Repair | 2 | 10-12-2006 06:44 AM |
| Weber 5E3 suddenly blowing fuses | sparky | 5 E 3 | 6 | 10-03-2006 03:37 PM |
| Mesa Mark III blowing caps | AtomicMassUnit | Maintenance, Troubleshooting & Repair | 8 | 09-06-2006 03:54 AM |
| Blowing fuses... | riscado | 5 E 3 | 7 | 08-21-2006 03:06 PM |
