| | #1 |
| Member Join Date: Oct 2008
| Best power / standby switches?
Hi! What do you use / like best in your amps? Carling are not made in the USA anymore, and I'm wondering if their quality has been going down or not. There are some affordable witches w/ high power rating that look like they're well made. Thanks for sharing! Victor |
| | #2 |
| Senior Member Join Date: Jul 2008
Dude, it's a switch.
| | #3 | |
| Member Join Date: Apr 2008 Location: Australia
| Quote:
I can't comment on Carling's toggle switches, but I find their stomp switches to be of poor quality and don't use them in effects pedals anymore. I also remove them from any wah's that I mod. | |
| | #4 |
| Member Join Date: Mar 2009 Location: Hoschton, GA (Atlanta)
Well, Honeywell makes good switches if you don't mind paying almost $14 for one. I use and recommend NKK switches, though. They are well made, tough and can be had for under $5. http://www.mouser.com/catalog/637/1627.pdf I don't know and really don't care where these are made. I believe NKK is a Korean company. All I know is they make good switches and I like and use them. Last edited by RogerWilco99; 03-13-2009 at 12:04 AM. Reason: Hit save too quickly. |
| | #5 |
I just visited the NKK Switches web site (http://www.nkkswitches.com). Their main office is in Japan, not Korea. They have a US office in Scottsdale, AZ (if that matters). As I said, though, where-ever their switches are made they are very high quality and I've never had a problem with one. They switch cleanly and with a definite snap to them. They aren't mushy with any kind of loose feel to them. Used per their specs, they don't short and they switch as they are intended. I believe if you try one, you'll like it. Cheers, Bruce Last edited by RogerWilco99; 03-16-2009 at 02:28 AM. Reason: typos and grammatical errors galore... |
| | #6 |
| Lifetime Member Join Date: May 2006
Then there is the heretical approach. I like power MOSFETs in the cathodes of the power tubes as standby switches. Turned on, they are 1 ohm (or less!) resistors. Turned off, they are open circuits compared to the rest of the circuit. You can use a P-channel in line with the B+ circuit and a couple of resistors and zeners to switch a P-channel, but then the whole thing floats up at B+. Putting N channels in the ground side turns off the ground side of the power supply. Done properly you can use *any* switch you like, even one rated for under 50V and a few ma, because that's all the switch sees. As for power switches, use any switch you like - to turn on a triac or solid state relay. Historically, every time I say this in public, I get a whole chorus of nay-sayers, and a few more people try it and it works. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Ampeg V4 ---blowing power fuse when standby engaged. | randomair | Maintenance, Troubleshooting & Repair | 12 | 01-06-2009 07:20 AM |
| Mini toggle switches? | OverDriven | Theory & Design | 4 | 07-01-2008 03:03 AM |
| Carling switches and Mouser | Paul P | Build Your Amp | 4 | 02-25-2008 06:58 PM |
| Marshall JMP 50w volume drops shortly after standby engages power | Thorny | Maintenance, Troubleshooting & Repair | 2 | 11-19-2007 09:31 AM |
| Boss Pedal Switches | ken | Guitar Effects | 5 | 06-05-2006 07:34 PM |
