| | #1 |
| Senior Member Join Date: Aug 2006
| how do i test a neon indicator light?
i've got a power light in my ampeg VT40 that won't light up. i have a replacement bulb pulled from another V-series ampeg, but i'm not sure if it works. so i don't want to switch the known bad one out for a potentially bad one. i would like to test the pull-out i have, how do i know if it's any good? can i use a 9-volt battery on the leads? or some other such simple test?
| | #2 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
Neons need about 100 volts to light them up, so the way to test it is to connect it to 120V from a wall socket. Be careful though, if you connect the bulb itself directly to 120V without a series resistor, it'll blow to smithereens. However, pretty much every neon pilot light assembly in the world has the resistor built in.
| | #3 |
| Member Join Date: Oct 2006 Location: Beautiful British Columbia CANADA
I just went through it with a v2- after puting it to a meter-Now I dont know if its the same or similar but for interests sake-mine ran off ac, I just put it on a variac and brought it up slowly to 120, the thing is, if its a standby lite which runs off the b+ you must check the voltage dropping resistor or it will just blow again. William |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Login Timeout? (test?) | Justin Thomas | Lobby | 4 | 04-06-2008 05:23 AM |
| how do I test for resonance? | corduroyew | Pickup Makers | 5 | 11-19-2006 04:57 PM |
| how do you test a PT ? | lil bubba | Maintenance, Troubleshooting & Repair | 3 | 08-23-2006 10:57 PM |
| Ampeg V4 Standby Light | dusty | Maintenance, Troubleshooting & Repair | 5 | 08-10-2006 07:36 PM |
| Could someone throw some light please - Mark, Please Help | Nbhatt | Guitar Effects | 12 | 07-06-2006 05:56 PM |
