Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders
Old 02-28-2009, 10:33 PM   #1
Supporting Member
Bias vary trem in 5F6A type amp?
My next build is going to be a 5F6A. (I have the trannies and the choke already.) I was wondering about putting in a bias-vary trem (because I really liked that in the 5G9 I built). So I add another 12AX7 (no problem for the PT). I understand (from my previous build when I tried subbing higher gain tubes in V1) that oscillator circuits can respond unexpectedly with 'chirps' and 'peeps' if the gain is different. Does anyone have an opinion on how well a 5G9 trem circuit would run in a 5F6A? (No doubt the values in the LFO circuit can be adjusted to compensate? - and I know I will have to get the plate voltage in the 12AX7 to a reasonable level)
Cheers
__________________
Old 02-28-2009, 10:57 PM   #2
Hi TW,
Why not just do as in a 6G16 (BrF '63 Vibroverb)?
MPM
martin manning is offline   Reply With Quote
Old 02-28-2009, 11:24 PM   #3
Wink Done that, works nice
Hi there!
I did that in my SF twin reverb because the opto coupler was dead.
It's totally different sounding IMHO.
When I build my Pro 5E5-A clone I added an extra 7 pin connector to supply the bias, B+, filament heaters and preamp in/out. This way I can hook up an external trem oscillator to bump the power tubes.
MaBerY is offline   Reply With Quote
Old 02-28-2009, 11:40 PM   #4
Supporting Member
Otherwise tweed bassman
Quote:
Originally Posted by martin manning View Post
Hi TW,
MPM
Good suggestion thanks Martin. (The PT I have is tweed bassman spec (325-0-325 200mA), otherwise I could build a 6G16, but no reason why the Trem circuit from the 6G16 wouldn't be good in the (otherwise) tweed bassman I guess).
__________________
Old 03-01-2009, 12:53 AM   #5
txstrat's Avatar
Hi TW
I don't see any problems with the bias-vary trem in the 5F6A (just don't bias it too hot).
The 6G16 is one of my favorite amps of all time but if you go for the classic Bassman sound you should stick with the 5F6A. As you know they're totally different sounding.
I think Martin meant the same, like just to use the trem in the WAY of a 6G16.
txstrat is offline   Reply With Quote
Bias-vary trem with cathode bias pwr amp? Groover Theory & Design 15 07-04-2009 12:46 AM
63 Vibroverb bias vary trem motorboating problem Victor Denance Maintenance, Troubleshooting & Repair 1 02-19-2009 11:14 PM
Unsteady Bias on 5F6A rymac Maintenance, Troubleshooting & Repair 8 10-22-2008 12:43 PM
5881's bias for 5f6a tweed5259 Tweed Builders 12 07-22-2008 10:11 AM
Bias-Vary Trem won't wiggle.... DMichel123 Debugging Your Build 5 01-27-2007 09:19 AM
