Go Back   Music Electronics Forum > Amplification > Tubes (Valves)
Old 03-01-2009, 01:35 AM   #1
Gaz
Last word on Sovtek 5881 plate voltages, pleeeeeease.
I'm trying to replace the power tubes in my Russian Red Bear MK 60, but I can't figure out a proper replacement. The stock tubes are Russian 6N3C-E (better known as the Sovtek '5881'). I thought it'd be in my best interest to switch to 6l6GCs - and just adjust the bias accordingly - until I found 'information' suggesting that the amp wouldn't sound 'good' with 6L6s, and that the Russian '5881' tubes can handle much high plate voltages.
According to every spec sheet I've found for the Sovtek 5881/ 6N3C-E, the maximum plate voltage is 250 volts, much lower than the plate voltage in my properly functioning Red Bear that has a plate voltage of 482 volts!
How could this be? Could the maximum plate voltage rating be rated at half of what's it's capable of? They are using these tubes in so many amps, and I can't believe the maximum plate voltage is actually that low. Most 6L6s can handle 500 volts on the plate, and I don't understand how the Russian 6N3C-E are supposed to have higher plate tolerances (BTW, the infamous Lord Valve stated that in his catalog).
Clarification would be a godsend.
Thanks.
Gaz is offline   Reply With Quote
Old 03-01-2009, 01:59 AM   #2
txstrat's Avatar
Just for the ratings you might go to:
http://thetubestore.com/tungsol5881.html which go up to 400v.
or: http://thetubestore.com/sovtek5881.html
or for a overview: http://thetubestore.com/6l65881types.html
There might be some fitting tubes...
txstrat is offline   Reply With Quote
Old 03-01-2009, 02:10 AM   #3
I did not find a data sheet for the 6N3C-E tube. But from what I've read in real world tests that tube can take up to 600V on the anode and has a max diss of about 40W. Perhaps the data sheet spec is for class A operation. From what I found you are not the only one to be confused by the data sheet. That tube is commonly used near 500V on the plate.
I think that tube is still available if you like the way your amp has always sounded. Otherwise the 6l6gc will "work" but I can't comment on the tone. Based on the tonee of those amps it would probably sound good with el34's too. But I don't know if the filament wind on the PT can handle the extra current. It probably can. That may require a modification to the bias circuit.
Chuck
Chuck H is offline   Reply With Quote
Old 03-01-2009, 03:03 AM   #4
Gaz
Chuck,
Thanks so much for the response. I concur that from all I've read "real world" tests have taken much higher plate voltages. I never thought about the limited charts I viewed only showing class A operation, so thanks for that thought as well.
Yeah, the EL34s would sound good, but I already have a Marshall 2203, and I've rewired the Red Bear's tone stack to a 5F6-A Bassman's because I wanted it to sound a little differt
By the way, where do you live in the PNW? I'm in Olympia, and about to move to Portland.
Old 03-01-2009, 07:46 AM   #5
I gotta say, everyone I've known that goes to Portland never leaves. Not in a bad way. People seem to like it there. I have to say that just driving through on I-5 I don't get the charm. But I've never taken any time to get to know Portland.
I'm on Whidbey Island.
Since you've already revoiced the amp a little I suppose that the reports of 6l6 tubes not being a good choice for that amp don't really apply to you anymore. They will operate fine in that amp. And since your looking for something NOT Marshall... If you can access a set for free that would be ideal. Then you could know before you buy.
Chuck
Old 03-01-2009, 09:12 AM   #6
Gaz
Yes, people seem to love Portland, especially young people like myself. All my band mates currently live there, and Olympia has less charm than a Russian 5881 (Sorry, but I thought I better keep this tube related).
Anyways, I was wondering because I was think about going to the Mike & Key Amateur Radio Club electronics flea market in Puyallup on the 7th. Ever been? Have any good finds?
Needless to say, I'm looking for some 6L6s, a capacitance tester, and maybe a deal on a functional tube tester...
Old 03-01-2009, 11:25 AM   #7
Welcome to Portland, a little in advance. Its a great place. Send me a PM when you gt into town and I can clue you in on some good stores and good places to jam at.
The Sovtek 5881 can take tons of voltage...probably up to 550v or more with a plate dissipation of 25- 30 watts. KG runs 12 5881's in his BAGA amp at very high plate voltages. They tend to sound better when whipped with high voltage and high bias too. They were made for Soviet military purposes and are the same as the Sovtek 6L6GB except in a different bottle. In fact, I have a couple of those 6L6GB Sovteks around, NIB, that I'd sell you cheaper than retail if you want them?
Greg
soundmasterg is offline   Reply With Quote
Old 03-01-2009, 09:57 PM   #8
Gaz
Thanks for the welcome!
So I'm starting to believe that these tubes can handle very high voltages, and the only things that's told me otherwise is the actual spec sheet
The spec sheet, which is apparently good for nothing, also states that the maximum plate dissapation is 20 watts. soundmasterg, so you're saying it's more like 25-30 watts? I totally trust you, but I'm curious as to how you arrived at this conclusion. Did you keep getting the tubes hotter until signs of red plating, backed off a little, read the bias, and did the math from there? That's the only way this newb can think of finding your own limits on a tube.
Old 03-02-2009, 12:24 AM   #9
Supporting Member
Steve Conner's Avatar
These were military grade tubes designed to last a long time. They can take a lot of abuse in guitar amps. Groove Tubes used to supply them, and Fender used to use them in their reissue amps.
Ken Gilbert tried to fry them with up to 600 volts on the plate, IIRC, but he couldn't break them. I wouldn't care to run them at that claimed 40W plate dissipation for long, though, unless maybe they were in some crazy Peavey style wind tunnel.
The spec sheet may well be correct, if the numbers on the front page were maximum operating conditions for one tube in single-ended Class-A service, not limiting values. If you're used to the "headline" page of a modern semiconductor datasheet, tube datasheets are laid out quite differently. The headline numbers tended to be these Class-A figures, which are also the ones that you had to set your tube tester to, if you wanted to check the operation of the tube. That is why these numbers got reprinted in the "Vademecum" tube guides and eventually found their way onto the intertubes.
But on a transistor datasheet the headline numbers are the ones that will blow it up if exceeded.
__________________
"Transformerless is the way to go", said he, without a hint of irony.
Steve Conner is offline   Reply With Quote
Old 03-02-2009, 01:08 AM   #10
Gaz
Thanks for the input, Steve. I'd already read a few posts discussing this particular tube in which you clarified a few things for me
So when doing my 70% biasing math, where is a reasonable spot to start with plate dissipation? I was previously following the spec sheet, which stated the maximum plate dissipation at about 20 watts, and doing the math as follows:
20w/482vdc x 70% = 29ma
Would 30 watts plate dissipation be more like it?
Any advice would be great. In addition, would 6L6GCs rated at 500vdc max. dis. be okay with this plate voltage (482vdc)? Do you think the tone would benefit, or should I stick with the Russian tubes the amp was designed with?
Thanks again.
Old 03-02-2009, 12:02 PM   #11
Supporting Member
I would consider the max plate dissipation about 25-30W on these tubes. I've seen the original RCA 6L6GCs, and the Sovteks look a good deal beefier, they have more plate surface area and a bigger bottle. But they don't look quite as hefty as a 6550 with its 35W rating.
29mA per tube will probably sound a little thin, I'd crank it to 35-40. The B+ will sag down somewhat under the extra current draw, so the plate dissipation won't be nearly as much as you think. Of course depending on your musical preferences, the thin tone may be perfectly OK, and it makes the tubes last longer.
Again, any Russian or Chinese 6L6GC type tube would probably work fine.
BTW, the Sovtek tubes go under a few different codes because of the transliteration from Cyrillic letters to English. I know this tube as the 6Pi3SE. Something to bear in mind when googling for datasheets.
__________________
Old 03-02-2009, 12:39 PM   #12
Supporting Member
As Steve said, 5881s were intended as a "beefier" military version of the 6L6, however, be aware that nowadays, some of the 5881s around are just "re-branded" 6L6s. I recently re-tubed and re-biased a JCM900 SL-X belonging to a friend, and when I opened the boxes I found that the Sovtek 5881s inside had "long sockets" and were mechanically and visually identical to some Sovtek 6L6s I had lying around. "Real" 5881s should have "beefier" plates and a very "short" socket.
Hope this helps
Best regards
Bob
Robert M. Martinelli is offline   Reply With Quote
Old 03-03-2009, 10:53 AM   #13
Gaz
I biased the Red Bear at 35ma today from about 25ma where it was at. Two words: tone town. Thanks for all the advice. BTW, fixed a friend's Sovtek Mig 100 today as well, which uses the same tubes, and the plate voltage measured at 545vdc. So yeah, these tubes can take a beating and sound just fine in both amps for loudloud rock music. Nothing 'harsh' or 'flabby' to my ear as some have said elsewhere about those tubes.
Old 03-03-2009, 01:58 PM   #14
FWIW I rebuilt a couple Red Bear amps for a friend and he had found a bunch of the odd output tubes and the strange preamp tubes for me to install.
After all was said and done, the amp didn't sound much different from any of the ones converted to run on 6L6's and 12AX7's.
drewl is offline   Reply With Quote
Old 03-06-2009, 01:44 AM   #15
Gaz
Yeah, i did the 12ax7 conversion, but that was just for ease of replacement and to have a little variety. I concur, it didn't change the sound much,
Old 07-28-2009, 09:13 PM   #16
hi guys! i hope some of you who posted in this thread are still around. I have been running JJ6L6s in my red bear mk 60 for about 3 months now and i think i want to try something different. To MY ears, the amp is still pretty harsh, and it only really cuts in the lows and highs in a band setting, and i want beefier mids. I am assuming the plate voltages on my amp are around the same as the guy who mentioned his, although i have never measure them. I also haven't really properly biased the amp, only messed around with the bias pot with the amp on seeing what i like best, and the bias pot is currently around 3 o clock or so, so the tubes are running pretty hot.
How easy would it be for this amp to take EL34s. That is basically what I am looking for. Or could there be a 5881/6L6 replacement that would be safer? I have done slight modifications on this amp so i would be able to do more if getting EL34s to run was easy.
carryonplease is offline   Reply With Quote
Old 07-29-2009, 05:28 AM   #17
El34's will give you a mid hump compared to 6L6's. I don't know how the power tube sockets are wired in that amp, so it's up to you to determine if EL34's are a plug and play tube (with bias adjustment of course. This may require one resistor change in the bias circuit). Just look at how your sockets are wired and pay attention to internal pin connections. Any mod to retrofit your amp to accept EL34"s should be easy. But, as I stated in a previous post on this thread, I'm not sure about the current capacity of the 6.3V PT secondary wind. I say (provided the sockets are wired correctly) plug in a pair of EL34's and bias it up. If the heater voltages don't sag and the PT doesn't get too hot you should be fine. Reading your post I think you would be happier with the EL34's if they can be made to work.
Chuck
Old 07-29-2009, 07:15 AM   #18
thanks chuck,
from my research about the amp i think i will have to mod the bias trim pot. according to what i've read and also what i've heard the bias pot has a very small range, only about 10k i've read. I would assume in order to properly bias EL34s i would have to work with the bias pot.
im not so much worried about the mod at this point. I am just wondering how I am going to find out if my transformer can handle the extra filament draw. There are no spec sheets and zero information about the transformers in these amps, other than the fact that the look pretty beefy.
I would assume since it is only 2 power tubes i am working with, that i safer than 4. but is there some kind of probe or kit i can use to test this?
Old 07-29-2009, 09:26 AM   #19
Plug the tubes in the sockets and see if the 6V drops. if it handles the extra current, then it will work.
DOn;t modify your bias first. Stick a voltmeter in an empty power tube socket and measure pin 5. If a 6L6 gets about -50 to -55 say, then your EL34 will wany more like -40 to -45. What does the adjustment give as a range of voltages? If the bias voltage goes low enough, then it is already set. That the adjustment pot is "only" 10k doesn't tell us anything. That is only meaningful in the context of the rest of the circuit.
You will want to install screen resistors, typically 1k 5w.
And EL34s need pins 1 and 8 wired together. MAny 6L6 amps use pin 1 as a convenient solder terminal, so make sure pin 1 is free to be connected to pin 8.
__________________
Old 07-29-2009, 09:25 PM   #20
are you saying i can plug in EL34s without modifications? That doesn't make sense, they have a different pin out?
What do you mean by "if the 6V drops?" Please explain this if you could.
I think i will want to make the bias pot have more of a range anyway first because i could quite possibly be runnning my 6L6s cold and i might just be happy with them running hotter. I still have yet to get any real readings so I will do that when i get a chance.
Old 07-29-2009, 10:14 PM   #21
Supporting Member
Alex R's Avatar
Perhaps I might presume to offer some explications.
Quote:
Enzo wrote:
"You will want to install screen resistors, typically 1k 5w.... And EL34s need pins 1 and 8 wired together."
These are modifications.
You can tell whether the heater winding can take the extra current draw EL34s require by plugging them in and watching whether the heater voltage holds up.
Alex R is offline   Reply With Quote
Old 07-30-2009, 02:28 AM   #22
What Alex said.
I specifically said don;t modify the BIAS first.
Right or wrong, it sounded to me like you planned to start changing bias supply resistors before finding out if the existing circuit had range enough already. I was suggesting you find out first.
__________________
Old 07-30-2009, 05:18 PM   #23
yea, i'm almost positive that is doesn't have a large enough range, from reading this website.
ringomedia.net - sankt-peterburg tube laboratory
He is talking about the 100 watt version here i believe
"The amp has a bias trimmer installed internally and interestingly the maximum idle plate dissipation I could set it to was about 16.5 Watts per tube. Seems there is no way to bias the tubes too hot without mods. The bias range I get from the trimmer is very small (it's only a 10k trimmer). I suppose this would be easy to change but I left it for now."
Old 11-02-2009, 09:48 PM   #24
The Sovtek 5881WXT is as close to indestructable as they come in guitar amps. Theres a reason they are the stock tube of choice in so many mass produced amps. Come to think of it Ive yet to have one fail on me in any of my amps. Bob
__________________
"Reality is an illusion albeit a very persistant one " Albert Einstein
rockon1 is offline   Reply With Quote
Old 11-05-2009, 05:03 PM   #25
Supporting Member
Alex R's Avatar
I just put a pair in an Ampeg VT40, to replace the 7027As. Talked it over with the customer beforehand, saying they would probably hold up but I couldn't guarantee it. I had switched the amp over to EL34s previously, but he didn't like the sound. Anyhow, 595vDC on the plates, idling at 15W per tube and not a crackle or a pop in an hour. They seem like happy tubes to me. Now don't take this as a recommendation or anything, but still...
Old 11-05-2009, 10:21 PM   #26
Fender ran them at 35W idle in a stock Prosonic. No problem, no redplating.
Tubes were tired after two years of daily use (several hours/day).
Cheers,
Albert
Albert Kreuzer is offline   Reply With Quote
Old 11-05-2009, 10:58 PM   #27
Supporting Member
Alex R's Avatar
- all that and they're cheap too. FGS this is the internet, write something bad about them or they'll be 50 quid apiece before you know it. You know, they destroy your soundstage or compromise your touch-sensitivity or something.
Plate voltage Tung Sol 5881 rymac Theory & Design 1 11-01-2008 03:55 AM
Help me understand plate voltages Garydean Maintenance, Troubleshooting & Repair 11 01-01-2008 07:10 PM
Plate voltages for a 5E3 macdillard 5 E 3 1 11-24-2007 07:56 PM
Effects of plate voltages? Doug Theory & Design 9 10-28-2007 05:37 AM
Real World 6P3S-EV/Sovtek "5881" test steve Theory & Design 10 05-14-2007 03:46 PM
