| | #1 |
| Member Join Date: Jan 2009 Location: New York
| Identify this cap? Hi guys can someone identify this cap for me It says .75p 1.5kv But when I look on Mouser to order it I cant find it. I dont know what the .75p means or what type cap it is. thanks |
| | #2 |
| Senior Member Join Date: Dec 2006 Location: York Pa
Looks to me like a 0.75pf 1.5Kv ceramic cap. Unless you've got an amp with over 1kv across this cap, I'd use this one as a replacement: http://mouser.com/Search/ProductDeta...OtS9kLgnIbA%3d
__________________ -Mike |
| | #3 |
Thanks anyone know what that double triangle symbol means on the board where this cap is. |
| | #4 |
It is not a cap. Seriously, .75pf would be the capacitance of the traces running to it. It is a transient suppressor, a spark gap if you will. If you had identified the amp or circuit it was in we could look the thing up for you. What is the component designation silk screened on the board by it? I bet it isn't "C" something. Is it shorted? is it actually bad? or do you just want to replace it because you don;t know what it is?
| | #5 |
Whatever it is--there are 2 of them next to the main Filter caps of a CTR Monitor They both have cracks on top--you can see the split in the pic. I'll look on the board to see if it says a C. thanks |
| | #6 |
It is not a crack, it is a slit. it is part of the item. What is CTR?
| | #7 |
| Member Join Date: Feb 2009 Location: Roanoke, Star City, Virginia
My first thought also was a spark gap but the symbol more closely represents a Gunn diode. I'd guess he meant CRT but that's only a guess. And if it is a CRT monitor, that would lean more towards a spark gap than a Gunn diode as I don't believe anything in there should be running at 10GHz or so...
| | #8 |
| Senior Member Join Date: Sep 2006 Location: Boscawen, NH
dollars to donuts it's in the flyback circuit of a CRT monitor. They are sometimes used as a high voltage bleed off...if the voltage gets above a predetermined level set by the size of the gap on the top, it arcs to ground and discharges off the excess voltage in the flyback circuit...
__________________ Tim Electronic Sound Technologies |
| | #9 | |
| Quote:
Its funny because in many monitor forums they did not know what this part was but I thought since I got great help fixing my amp here I'd post here for identification. Those dingbats had me spinning in circles. Finally I did a crash course in CRT's and found my problem must be the vertical IC or its surrounding caps. I replaced the caps and my picture filled the screen again with no distortion on the bottom. But a few hours later I could see the problem coming back a bit. So I changed the V IC and a cap and it was norm again. Next day it started again--so it seems something is shorting out the vertical section from outside. I replaced the main filter cap(the pic was not the flyvback but the main FC). Anyway I though the part was a cracked cap--but now I know better thanks guys Last edited by alien; 03-04-2009 at 02:11 AM. | |
| | #10 |
I have also worked in the arcade business for many years, and all those arcade games have video monitors runnning 16 hours a day. Big old CRT based monitors. BY FAR most problems are dreid out electrolytic caps. In fact a couple companies sell "Cap Kits" for monitor models. Each is just a collection of the various values used int he circuit. Basically replacing all of them. it solves 90% of the p-roblems. Look at your board. ANy caps with the plastic cover on the cap shrinking back? Replacce them. You replaced as couple caps in the circuit, replace the rest. Don;t forget that little 1uf/50v one behind the V driver heatsink (or whatever). You may have vertical caps spread around too, not all right together. Watch part number series for example. And if it takes warming up to show the symptom, get a can of freeze spray and selectively cool areas to look for a sensitive part. If you freeze a part and the picture snaps back to normal, there you go.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Can you identify this Teisco tube amp? | ian2113 | Vintage Amps | 1 | 04-26-2009 09:49 AM |
| Help identify a part please! | PurpleStrat | Conversions | 3 | 08-30-2008 08:24 PM |
| Please identify these pickups | Leka | Pickup Makers | 10 | 08-05-2008 01:21 PM |
| help me identify this pickup | guitardude | Guitar Tech | 6 | 08-04-2008 06:05 PM |
| Can anyone identify this speaker? | Bill Moore | Vintage Amps | 2 | 08-14-2007 07:07 PM |
