Results 1 to 2 of 2
Thread: Two humbucker, two volume, two tone wiring
    Senior Member Ruel's Avatar
    Jun 2006
    San Pedro, Laguna, about 45 minutes to an hour from Manila
    221
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    How do you wire a two humbucker guitar, with two volume pots and two tone pots in such a way that the volume controls work independently of each other?
    0 Not allowed! Not allowed!
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,945
    Thumbs Up/Down
    Received: 0/0
    Given: 0/0
    You want to wire your volume controls up like a Jazz bass or Rickenbacker.
    So instead of the pickup wire going to the outside lug on the pot, they go to the middle, and the output comes from the outside lug. The tone controls also get wired to the middle lug where the pickup wire is connected.
    Keep in mind that when both pickup are al the way up, one tone control will effect both pickups. Also when you turn a pickup partway down, you loose some high end because of the loading of the pot.
    You can follow this Rickenbacker schematic for a 2 pickup, 2 vol-2 tone guitar.
    http://www.rickenbacker.com/pdfs/19501.pdf
    http://www.seymourduncan.com/support...c=rickenbucker
    It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. Albert Einstein
    http://coneyislandguitars.com
  1. Piezo wiring w/ tone & volume
    By Jack.Straw in forum Guitar Tech
    Last Post: 04-27-2009, 04:53 PM
  2. Is this normal wiring for tone and volume?
    By bhuether in forum Guitar Tech
    Last Post: 02-05-2009, 01:52 AM
  3. Swapping North and South Humbucker Wiring?
    By bhuether in forum Pickup Makers
    Last Post: 01-30-2009, 01:31 AM
  4. humbucker wiring convention...
    By Possum in forum Pickup Makers
    Last Post: 12-25-2008, 03:53 PM
  5. humbucker bobbin wiring
    By Marco Pancaldi in forum Pickup Makers
    Last Post: 02-03-2007, 10:40 PM
