Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders > 5 E 3
Old 03-04-2009, 05:49 PM   #1
Low voltages
Hello.
I've been working on converting an RCA console amp to a one channel 5E3. I've got it running and I'm wondering about the best way to deal with my voltages. I seem to have too little in the power amp section:
327 vdc at recto.
303 vdc after the 5000r
252 after the 22k
6V6's
pin 3 319
pin 4 307
pin 8 17.7
pin 3 324
pin 4 306
pin 8 17.7
Cathode resistor is 250r
12ax7s (I don't have a 12ay7 in V1)
V1
pin 1 159
pin 3 1.5
V2
pin 1 180
pin 6 217
My filter caps are 40uf/40uf/20uf (all 450 volts) If that makes any difference. They were what I had on hand.
Any insight would be greatly appreciated.
distorto is offline   Reply With Quote
Old 03-04-2009, 06:43 PM   #2
Supporting Member
What sort of rectifier have you got in there? If it is a tube rectifier, unplug it for a moment and measure the VAC on pins 4 and 6. That should tell you whether the PT has got enough juice (~320-325VAC on each side) to get you into the 340-360 Zone with a 5Y3GT rectifier. If it hasn't, you may want to put in a 5V4 or a GZ34, or just use diodes (which may give you more than you need)
__________________
Old 03-04-2009, 07:05 PM   #3
Thanks for that.
I have a NOS 5Y3 in there now. I get 326-326 vac on pin 4 and 6 with the tube pulled. I have a unmarked rectifier tube here that gives me better voltages. It looks like a GZ34 but it warms up slowly. Any idea how to identify this tube? Also with this tube in my preamp/PI voltages get a little high:
V1:
pin 1 184
V2:
pin 1 204
pin 6 243
If I go with this tube should I adjust the 22k dropping resistor? I also have a NOS 5u4 GB but that would probably draw too much heater current?
Thanks a bunch for your help
low...low...volume. Mesa .50 Garydean Maintenance, Troubleshooting & Repair 18 01-15-2010 03:18 AM
low-z...ultra low...but if I.... scottmccullor Pickup Makers 11 03-09-2009 08:50 PM
Voltages ok?? Ringwraith 5 E 3 3 05-17-2008 07:31 AM
Trouble with old amp: voltages too low. Bad power transformer? slidincharlie (Carlo P) Maintenance, Troubleshooting & Repair 15 11-28-2007 07:48 AM
Traynor custom 40 low voltages Guitarist Maintenance, Troubleshooting & Repair 3 01-31-2007 10:14 AM
