| | #1 |
| Senior Member Join Date: Apr 2007 Location: sydney australia
| temporary intense glow/dull flash on filament when heaters are turned on
in my old holden/wasp amp 1 of the 12ax7's filament will have an intense glow as the heater is turned on, and settle to the normal glow after a second or 2. all other tubes slowly start to glow over a couple seconds, but this one is instantaneous and much brighter than usual (but only for a short period). i repeat, the intensity is only for a moment, and it returns to normal over the next second. it is only one tube any explanation for this? is it a bad thing? is it maybe a different material used for the filament which reaches the operating resistance once heated (as resistance rises with heat)? |
| | #2 |
SOme heaters do this.
| | #3 |
thanks, i was a bit worried, as there are 3 of the same tube type in the amp, and only one does this.
| | #4 |
| Senior Member Join Date: May 2006 Location: Phoenix
This comes up every once in a while here. Some tubes were designed for a faster turn on in TV's, radios, etc. Those are the ones that 'flash'. Usually there's no clue on the box or tube if it is fast or slow, just plug in and watch.
| | #5 |
| Member Join Date: Apr 2008 Location: Australia
black_labb: I don't suppose this was with an Aus made tube was it? I was having the same thing happen with an old AWA Radiotron 12AX7 today and it freaked me out!
| | #6 |
| Supporting Member Join Date: May 2006 Location: Glasgow, Scotland
I've seen quite a few preamp tubes that do this. I don't know why it happens, but it doesn't seem to cause any harm.
__________________ "Ohhhh miracle bulb shines feebly" |
| | #7 |
| | #8 |
| Senior Member Join Date: May 2006 Location: Manassas, VA
all my Phillips 12AX7s do this.
| | #9 | |
| Senior Member Join Date: Jul 2008 Location: Auckland
| Quote:
Your heater glow is quite normal. Does your Wasp still have 4 preamp valves? Quite a few of them were severely modded to only use two valves, I have just completed a complete restoration on a 200 Wasp. | |
| | #10 | |
| Quote:
which one did you restore? any pics anywhere? did you change the electrolytics? i've been meaning to do that, but they seem to be fine. | |
| | #11 | |
| Quote:
Replaced everything except the preamp pcb and the transformers. Made a new power amp PCB, original board was charred. restored the cabinet also. I used 3x 33uF 450v electrolytics to replace the ones on the PCBs, I have plenty of these NOS caps if you want some. (they are small axial lead type and fit perfectly) Some of the diagrams on anz site are missing cap values I can fill in the gaps there. Roly the web site owner wants me to send him pics which I will send him when I have written some blurb to go with them. | |
| | #12 | |
| Quote:
You will find my local Trade and Exchange (online newspaper) work wanted adverts. | |
| | #13 |
| Senior Member Join Date: Nov 2008 Location: Norwalk CT
| Yep Philips and other Euro pre amp tubes will flash. Totally normal.
__________________ "Reality is an illusion albeit a very persistant one " Albert Einstein |
| | #14 |
| Senior Member Join Date: May 2007
My old teacher explained this that the valve wasn´t 100% completly sealed and burned air.
| | #15 | |
| Quote:
Wish I could get my old V8 to burn air! If there was air in the tube the silver coating on the inside from the getter would oxidize and the tube would turn white. The filaments are designed to handle the inrush current on switch on. My old employer used to fill out service sheets " Replace rectumfire valve and tune for maximum smoke" | |
| | #16 | |
| Quote:
| | #17 |
| | #18 |
I don't buy the "burning air" thing either. (To be pedantic, your V8 burns air already, or rather burns the oxygen in it by combining it with gasoline. If you don't believe me, try bunging up the carburettor so no air can get in. This really improves the gas mileage because the engine won't work and you can't drive anywhere.) If a tube flashes, it's because there is a relatively long piece of heater wire left uncovered by the white stuff that forms the heater-cathode insulation. The resistance of tungsten increases with temperature, so if one part warms up quicker than the rest, it will drop more voltage and heat even more, in a vicious circle until it's dropping nearly the full 6.3V and glowing white hot. This is what the uncovered lengths of heater do, because the lack of white stuff reduces their thermal mass. As the rest of the heater begins to warm, the white hot ends dim down and eventually go out. Some people say that this is deliberate, as it slows the warm-up of the rest of the heater, protecting the white stuff from cracking due to thermal shock. I suspect that Philips just found it difficult to coat the heater all the way to the ends.
__________________ "Ohhhh miracle bulb shines feebly" Last edited by Steve Conner; 03-25-2009 at 12:44 PM. |
| | #19 | |
| Quote:
__________________ "Reality is an illusion albeit a very persistant one " Albert Einstein | |
| | #20 |
Just don't crack the glass. if the burning air inside the tube manages to get out, it could catch the earth's atmosphere on fire, and then we'd be screwed.
| | #21 |
| You could avert that kind of disaster, just use your Goniometer to track the radioactive "white stuff" from the burning filaments.
| | #22 |
| Senior Member Join Date: Apr 2008
I read somewhere that 12AX7As and 7025s don't do this, it's just 12AX7 (early US) and ECC83 (euro) valves, something to do with 12AX7A being designed for series string operation. It's most definitely the low initial resistance of the heater. For what it's worth, most of my mullard 12dw7/7247s do this too. Sure makes startup look dramatic |
| | #23 |
| Supporting Member Join Date: Feb 2007 Location: Wellington NZ
Sure is dramatic - its a little fireworks party when you flick the switch on. Hey unparalleled, where d'ya get them gonzo meters?
__________________ Building a better world (one tube amp at a time) |
| | #24 | |
| Quote:
Goniometer, google it ( direction finding device. ) (Not for detecting severity of VD) | |
| | #25 |
| Junior Member Join Date: Apr 2009 Location: northern california
Most Euro made ECC83 tubes do this on power up. No harm is being done, the filaments just flash or glow bright for a few seconds. My friend has a few ECC83 tubes in his Hi Fi amp. They have been inservice and doing this for years in his amps. I believe they do the same thing in regulated D.C. filament supplies. NO worries |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Getter halo turned dull and brownish: tube still good? | slidincharlie (Carlo P) | Maintenance, Troubleshooting & Repair | 6 | 11-23-2008 09:33 PM |
| marshall tsl 602 - dull sound | spunicz | Maintenance, Troubleshooting & Repair | 13 | 10-22-2008 07:16 AM |
| Flash Point | NightWinder | Pickup Makers | 5 | 04-19-2008 07:39 PM |
| Non-S.O.I.C. Serial Flash? | kingsteven | Music Electronics | 5 | 09-24-2007 11:48 AM |
| El84 blue glow inside tube ! | walkman | Debugging Your Build | 4 | 06-08-2007 01:42 AM |
