Go Back   Music Electronics Forum > Amplification > Harp Amps
Old 03-05-2009, 10:29 PM   #1
suppressing highs at the speaker
All speakers have the limitation of the high frequency response. I have two questions: 1) If a speaker is rated for say 30 to 15k hz response, how much of that can actually be heard (on the high end of course)? 2) Because the highest frequency response is most likely a function of the weight of the moving voice coil and cone, inertia, wouldn't increasing that inertia take out some of the highs? I suppose that another piece of the response is reactance of the voice coil. Any thoughts?
Shepster is offline   Reply With Quote
Old 03-06-2009, 12:15 PM   #2
Supporting Member
Quote:
1) It depends on the speaker, you should look the frequency response chart of the speaker under evaluation to state this.
2) Inertia is most important at lower frequencies IMHO, higher frequencies don't cause the coil and the cone to move that much because the wave length is way shorter at higher frequencies. Proof of this can be heard when you play through a speaker at low volumes, the highs are there, but to get lows you need to raise the volume.
3) Reactance - That's one important piece of the puzzle...and...I guess you're talking about Inductive Reactance ( since the coil's stray capacitance is so little that it can be surely neglected together with its Xc at audio frequencies ).
Speakers have a nominal impedance, but in the real world impedance changes with frequency, being the square root of the coil resistance squared ( "real" part of the impedance, not frequency dependent ) plus the Inductive Reactance squared ( "imaginary" part of the impedance, frequency dependent ). And, yes, it actually increases with frequency, because Xl = 2Pi*F*L ( Inductive Reactance ).
HTH
Best regards
Bob
Robert M. Martinelli is offline   Reply With Quote
Old 03-06-2009, 08:17 PM   #3
guitician's Avatar
If the speaker is rated for a -3db response, at 15khz, you would be "hearing", "half" of the nominal 1 khz sound pressure. I once used butyl to dampen harsh highs from a small speaker by coating the entire cone with it. It worked well but was not "Hi-Fi"
guitician is offline   Reply With Quote
Old 03-06-2009, 10:17 PM   #4
The frequency response means that is what can be heard, assuming the listener's hearing is good, and they are in the normal sound field, ie on-axis and at a reasonable distance to the speaker.
A regular guitar amp might have trouble putting out full power at 15kHz, especially if the speaker impedance may be >2x the nominal , but most guitar speakers are way down by then. As am I. Peter.
pdf64 is offline   Reply With Quote
Old 03-07-2009, 07:03 AM   #5
Supporting Member
Quote:
+1.
I guess most of us have problems in hearing whatever lies above 10-12 KHz. I surely have ( what did you say? talk louder, I can't hear you ! ).
Anyway...I 'd say that the frequencies above 10 KHz count only in Hi-Fi apps, and they are of little or no interest for guitar IMHO.
Bob
very old amp w/non PM speaker. Customer wants PM speaker installed. tim Maintenance, Troubleshooting & Repair 4 02-24-2009 11:34 PM
faulty speaker? chacone87 Maintenance, Troubleshooting & Repair 5 10-27-2008 12:15 AM
HV on speaker Two Tone Maintenance, Troubleshooting & Repair 14 10-25-2008 07:45 PM
Dynamic Speaker to Permanent Speaker alphamarquis Debugging Your Build 18 01-05-2008 03:03 PM
Need some speaker help! Craig Music Electronics 2 08-23-2006 08:57 PM
