Page 1 of 2 12 LastLast
Results 1 to 35 of 43
Like Tree4Likes
Thread: Marshall MG250DFX - Smoke Generator!
    Feb 2009
    SE Michigan
    4
    This thing had 2 burned TDA7293s.
    All pre-amp circuits are working properly.
    All values on the power amp plug pins seem correct.
    When I plug in the power amp module (with a new TDA7293) the speaker (for that side) emits a loud tone (like feedback), and the chip get very hot, very fast.
    I think there is some sort of runaway loop problem related to the feedback circuitry, but I can't seem to pin it down.
    I will appreciate any ideas; thanks!
    Dan
    Jun 2007
    4,960
    Quote Originally Posted by DetroitDan View Post
    Don't try hot swapping these modules, as you will kill the new chips.
    Are you reading any DC on the output with no speaker?
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    29,162
    ANy chance you have swapped the cables to the modules? That is, so Channel A is driving module B and vice versa?
    AND GET RID OF THE SPEAKER. Don;t hook up a load until you are sure the amp is stable.
    Jun 2007
    4,960
    And when it is stable, shut it off before plugging in the speaker to test the amp.
    Feb 2009
    SE Michigan
    4
    Thank you for the suggestions.
    The chip(s) get hot, immediately, even without a speaker. There is no time to measure DC out - The chip will burn
    No hot-swapping. I plug the module(s) into the main board; hit the power; and instant heat. Every permutation has been tried, one, both, A-only, b-only; output jacks disconnected
    I've tested each of the pins to the module, with a DVOM, and scope, without the PA module connected.
    Nice 1vp-p signal; +36;-36v; grounds seem good(<0.1ohm); mute rises from low to 6.45v; Output not grounded (I think it was about 4.5k ohms w/no speaker, after a cap charge rise from 2.5k).
    Crazy.
    I picked this up with both power amps burned; so, I don't know the history. None of the main board circuitry seems to have been disturbed.
    Dan
    Feb 2009
    SE Michigan
    4
    I just read all of the threads I could find regarding the TDA7293; yikes!
    I'll hook up my variac and bulb limiter, and try a little slower path.
    I generally only work on tube amps, but lately, have ended up with some burnt Line6's and SS Marshalls.
  7. #7
    May 2012
    4
    Hi DetroitDan - I know this thread is quite old, but I have the same amp model with same exact problem, exact behavior and readings. Did you manage to fix your amp? I have blown 4 TDAs already and no solution to the problem. Any further feedback from your troubleshooting will be greatly appreciated.
    Thanks,
    JoKeRz
  8. #8
    Senior Member booj's Avatar
    Jun 2008
    629
  9. #9
    May 2012
    4
    Thanks booj. I already had the schematics and used it to follow the signal throughout the circuit. Pre-amps are ok and I get sound on the headphones jack. Just wonder if DetroitDan was able to fix his amp and how. I've already unsoldered several components to check if they are good and so far no culprit. Thanks!
  10. #10
    Supporting Member TomCarlos's Avatar
    Oct 2009
    Roseville, Ca.
    541
    I just started working on a MG250DFX for a friend. It was making a loud screech at turn on. So I swapped the speaker cables and was able to isolate the problem to one side. After a little soldering on the power chip leads, I tried to fire the amp up again. It seems to be working.
    I cannot believe the SMALL heatsink for these two power ICs. The other thing I am not sure of (cause someone else worked on this amp before me) .... The fan... should the air flow be flowing into the amp or out of the amp? I think the fan was in backwards!!
    Tom
  11. #11
    May 2012
    4
    TomCarlos: the fan should be blowing the hot air out of the case, like an exhaust fan. I can confirm that was the configuration of mine when I first opened it.
    In my case, something is clearly not correct in the main board / components. I can tell that because I have already meticulously checked all components and contacts in the little power amp board several times before and after attaching a brand new tda7293 (I ended up soldering an IC socket to make it easy to swap the 7293s) and still I blow up the TDA a couple of seconds after I turn it on (with smoke if I leave the main power switch on further). The power amp board and heatsink are not touching the chassis nor any other part (so no chance of short circuiting the +V and GND) and at this point I really cannot pin point the culprit, but haven't given up.
    Anyone with similar problem on MG250s, MG100s MG50s, AVT150s, etc (Marshall SS based on TDA7293), please share your successful experience fixing this. Thanks!
  12. #12
    29,162
    Hi, welcome.
    So stop burning stuff up. Look up "light bulb limiter." Simple thing, make one and use it.
    Whenever one 7293 blows up, I always replace BOTH of them.
    Operate WITHOUT a speaker load until the amp is stable and not making DC on the output.
    Disconnect the power modules. verify proper power supply voltages at the connector cable.
    NEVER connect the cable to the power module without verifying the power supplies are completely discharged.
    The little parts on the power module boards rarely fail, but problems elsewhere in the amp can cause problems with the 7293s.
  13. #13
    Dec 2008
    Wernersville, PA
    11,963
    This is THE most important item.
    You cannot connect the TDA ic with power 'floating' on the rails.
    They WILL fail.
  14. #14
    29,162
    For that matter, do not DISconnect themk with any power in the system.
  15. #15
    May 2012
    4
    Hi Enzo and Jazz P Bass – I had read a lot (really a lot) of previous issues concerning the power module amps with TDA7293 and your great feedback in those threads. I am following all the tips you have provided in those and have a fairly good understanding of electronic circuits so let me give you a bit of more details of my situation and what I tried so far:
    - Both power amps were dead once I god this unit, as well as the 3.15A fuse blown and the standby circuit zener (6.8V, called D19 in the MG250GFX schematics) opened.
    - First attempt was to just replace the fuse, and that just made another fuse go away. Since I did not have an incandescent bulb at that time (just fluorescent ones),no go for a light bulb limiter and I could not wait until next day so I decided to just put a jump cable in the place of the fuse and do quicks turn-on/off in the main switch. I could notice the traditional silicon burning smell after a quick on/off and if I left the switch on for a few more seconds, smoke on both power amp modules.
    (that is when I started researching on forums like this)
    - I ordered several TDA7293 so I could play (and burn a few on the way). I ordered them from an ebay seller from which I had ordered parts before (seller located in the US) and latter on I read in some websites this IC can be fake. I really did not believe that, but just to make sure I used my multimeter to read resistance between some pins and it seem to match the internal schematics of it
    - So I rereplaced the 6.8v zener (first removed it, and checked if there was still a short between transistor pins / capacitor, and there was none), checked all capacitors and connectivity of the power module board and re-soldered a brand new tda7293. I made sure to drain power from the big electrolytic capacitors before reconnecting the board. Once unit was turned on (with no speaker out) smoke again. Very quickly. Funny thing is that the heat sink was not even warm so the IC blew without generating heat. Oh, forgot to mention: the chassis of the 7293 (which has -VCC) is not insulated from the heat sink so I made sure not to let it touch any part of the MG250DFX chassis (isolated by a piece of 2x4 pine wood )
    - Next I decided to solder IC sockets so it would be easy to remove and add another tda7293 as necessary (I am afraid to lose the PCB tracks after so many re-soldering). After I did that, I attached another new tda7293, confirmed all connections to the terminals of the power amp module cable (all 15 pins) and then turned the unit on (discharged capacitors before) and, again, tda7293 blown followed by zener blown.
    - I could not find any other problems with the main board. I am testing with just one of the modules (which should be ok since this is a stereo unit so each power module is independent for L/R. If you see a problem with that approach, please let me know).
    - I have also checked contacts in all 1/4in jacks, including plugging a cable from fx out to fx in (I read in same threads those could be causing some short circuits)
    - Also forgot to mention: headphones output works like a charm, with both clean and overdrive channels working as well as effect processor unit and reverb. So the pre-amp / effects part of the circuit seems to be ok. I even connected the power amp board WITHOUT TDA7293, and made a direct connection from IC sockets 2 to 14 which pretty much connects the input directly to the output (without power amplification). Doing that and plugging a speaker in the speaker out jack I could even hear the input signal (very low volume, of course) and the main pot also worked controlling the overall volume. That is why I am a bit skeptical of a major problem in the main board. But, still, cannot pinpoint the where the problem is.
    - For next troubleshooting steps I have two approaches:
    1) I ordered a new power amp board, pre-assembled, from ebay, using LM3886. Once I received it I will test it isolated and then try to connect it replacing the original TDA7293 from marshall. I just read in many places that the LM3886s are less sensible and should not blow that much
    2) in parallel, I am trying to use the original marshall power amp module with a new TDA7293 by just connecting +vcc/-vcc/gnd from the main board and feeding my own input signal (already pre-amplified) and checking the output with multimeter and then with an old speaker (yes, do not want to risk blow a good speaker). The goal here is to confirm the problem is not in the power amp board itself (neither a “fake” 7293) to then focus on the main board components. Then I can plug input from main board to see it still works so I can pin point if the problem is in the circuit before the power amp or after (where the main output pot is).
    Well, that is pretty much a summary of my problem and attempts. So far did not find the culprit. I will make sure I use the bulb limiter going forward. Unfortunately I only have one digital multimeter as a tool (no scope, not even a variac to play with input voltage). Please let me know if you guys can suggest any other troubleshooting step. Tonight I will perform another inspection on the main board.
    Many thanks,
    JoKeRz
    (sorry for the long post)
  16. #16
    Mar 2015
    14
    Hi. I know this is an old post but did anyone ever find a definitive answer to this seemingly common problem?
  17. #17
    Dec 2007
    Poland
    1,526
    Quote Originally Posted by Andy1960 View Post
    I don't remember the details but the problem (and solution of the problem) was described on this forum. Some problems were caused by users trying to fix the amp but forgetting to isolate the IC from the heatsink. But, as far as I remember, the main problem was that one of the pins of the IC wasn't connected on the PC board as suggested in the datasheet by the manufacturer of the integrated circuit. Maybe someone else remembers more details. You have to either search the forum, or look very carefully at the datasheet and compare it with the board you have. It seems to me that the original design was for an old version of the IC. So you have to find out a new datasheet for currently manufactured IC.
    Mark
  18. #18
    Mar 2015
    14
    Thanks for that Mark, that throws a spanner in the works! Ive trawled all through for a definitive answer but found nothing so far. Id thought about the IC isolated from the heatsink but the heatsink is actually isolated from the chassis so shouldnt be a problem. The rogue pin is a new one on me, I hadnt read that before, Ill check the data sheet.
  19. #19
    Dec 2007
    Poland
    1,526
    Another problem that I remember (but it is not the case you have) was that some company in the States was selling replacement boards for the power amp but they made a mistake when designing the PC board. As a result all replacement boards were failing on first turn on of the amp. This case is also described on the forum.
    Mark
  20. #20
    Mar 2015
    14
    Yes I read about that. As you say unlikely in my case as Im in the UK so even if they have been replaced its not going to be with US ones I wouldn't have thought. Everything runs fine with the boards unplugged and Im loathe to believe theres anything wrong with the electrolytics on those boards although that was suggested on one thread on here. They all measure accurately on a capacitance meter anyway.
  21. #21
    Dec 2007
    Poland
    1,526
    What about contacting Marshall directly:
    Denbigh Road
    Bletchley
    Milton Keynes,
    T: +44 (0) 1908 375411 ?
    Mark
  22. #22
    Mar 2015
    14
    Are they helpful in that way? Some manufacturers dont like giving out repair info. I used to be a tv engineer years ago and every manufacturer had a tech dept who would help if you were in the trade. In the end they started charging for it. I'll give them a try
  23. #23
    Dec 2007
    Poland
    1,526
    I would give them a try. There is a big chance that they are "user-friendly".
    Mark
  24. #24
    Dec 2008
    Wernersville, PA
    11,963
    Somewhere around 2003 the TDA7293 Slave mode pin hookup was changed by the IC manufacturer.
    It was now recommended that on the slave ic, Pin 2 & 3 (Slave +In/ -In) & pin 4 (Slave Ground) be tied to the V- rail.
    On the MG250's, these pins are at a ground connection. (like the older datasheet indicates).
    Whether or not this causes an issue was not really indicated.
    There was a follow up post to this issue where the OP did make the changes & the amp did function properly.
    At any rate, the key to working on these amps is that the power supply must be drained before working on the circuit.
    And most importantly before the IC's are reconnected to the board.
    Edit: the main post on the TDA change concerned a Marshall Mode 4.
    It should also apply here.
    Original post: Marshall Mode 4 (mf-350) IC's blowing up
    http://music-electronics-forum.com/a...cb-modules.doc
    Attached Files Attached Files
    diydidi likes this.
  25. #25
    Mar 2015
    14
    Hi, Ok so are we saying that the chip itself has changed or just the recommended connections? I did read something similar from a guy wanting to use a 7293 in place of a 7294 I believe. Yes I know about draining the caps I've been careful with that.
  26. #26
    Dec 2008
    Wernersville, PA
    11,963
    I do not know if there was an actual internal change to the IC.
    I do know that the 2003 datasheet is different.
    (the 2010 datasheet shows the same slave hookup as the 2003)
    davman actually contacted a rep with this reply:
    (Marshall Mode 4 (mf-350) IC's blowing up)
    "I contacted a Field Applications Engineer from the chip manufacturer, who said it would be difficult to find the relevant info to explain the change - however, any TDA7293 purchased after the the latest (2003) datasheet should be wired to the application circuit recommended there.
    In other words, the 2 Slave TDA7293's must now have +IN & -IN wired to -Vss. "
    The 7293 & the 7294 are different chips.
    I would not swap them.
  27. #27
    Mar 2015
    14
    the mg 250 though just has the one chip per output
  28. #28
    Dec 2008
    Wernersville, PA
    11,963
    Oopsie.
    Belay the last posts & file it under ("Parallel/ Slave Changes.)
    In that case, there are no known issues with the IC.
    Other than there inherent limitations which tend to be exceeded.
  29. #29
    Mar 2015
    14
    Just spoken to Marshall and they said the only problems they had with this chip was either because of not discharging the power supply before connecting (which i have) and the heatsink being shorted to the chassis (which it isnt)
  30. #30
    Jun 2007
    4,960
    Andy1960- You have asked about a definitive answer to the problem, but you have never stated exactly what your problem is. Are you blowing up new chips? Are you testing without a speaker load? Are both outputs dead? What have you checked so far?
    Please help us to understand what your situation is and maybe you will come up with the definitive answer to these problems. I haven't had to fix a lot of these, but they don't seem to be any worse than the bigger multiple chip ones. Once you get it working, they seems to work just fine until somebody does something to make the output chip unhappy.
  31. #31
    Mar 2015
    14
    Hi 52Bill. The problem im having is identical to the one posted by JoKers about 15 posts back. Yes new chips blow straight away, both outputs the same, checked everything JoKers did. No load apart from the first time but Im told these will run with no speakers attached as long as you dont attach a load while powered up. The chips blow instantly its not liek they overheat. this problem reoccurs all over the forum and in fact the internet regarding these TDA7293's in various amp models and while some have managed to repair them there doesnt seem to be any rhyme nor reason to the repairs, its almost sheer luck.
  32. #32
    Jun 2007
    4,960
    So it will power up fine without the power amp chips connected? All of the supply voltages are correct, including the standby voltage? And you have tested all of the parts on the power amp chip boards and the input circuitry that they connect to? How about the speaker jacks and wiring?
    Are you using some sort of limiter when powering up, like a variac or a light bulb fuse saver? If both power amp chips blow, then it should eliminate some things and lead you to some others. Where did you source the new chips?
  33. #33
    Supporting Member The Dude's Avatar
    May 2010
    Sioux Falls, SD
    4,702
    Also, make sure the heat sink is isolated from the chassis.
    “Yeah, well, you know, that’s just, like, your opinion, man.”
  34. #34
    Mar 2015
    14
    52Bill, Yes without the boards connected it all powers up fine and the preamp works fine. Supply voltages are all correct. Standby voltage was previously at 12 due to the zener being open but is now 9 but either is within safe limits. Speaker jacks are ok with no shorts on the output. All caps on the amp boards check out fine and Dude, yes the heatsink is isolated by the fan with no shorts to chassis.
    the chips in both channels blew but ive only been testing it in one since it is just two identical outputs, not bridged etc.
    You are about the fourth person to ask where I got the chips from and I have been suspecting it could be the chips but they are ST branded and I didnt get them from China which is what everyone seems to ask.
  35. #35
    Dec 2008
    Wernersville, PA
    11,963
    I have to ask.
    Where did you purchase the IC's?
    (They may be bogus.)
  1. Old Heathkit Audio Generator
    By Bruce / Mission Amps in forum Flea Market
    Last Post: 11-03-2008, 12:09 AM
  2. Ampeg vt-40 combo old enough to smoke
    By Rays in forum Guitar Amps
    Last Post: 06-09-2008, 02:25 AM
  3. Fender M80 - square wave generator!
    By Ron in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-05-2007, 01:57 AM
  4. Guitar Effects Generator Specs
    By Leven in forum Guitar Effects
    Last Post: 04-25-2007, 08:02 AM
  5. Signal Generator Advice Needed
    By bob p in forum Music Electronics
    Last Post: 01-24-2007, 07:56 PM
