Go Back   Music Electronics Forum > Amplification > Guitar Amps
Guitar Amps General discussion about amps
Old 03-08-2009, 09:03 PM   #1
Power soak help
I have Sholz power soak that I want to use with my amp. My amp is a Epi Valve junior head w a 12" 15 ohm ext speaker. The power soak is designed to use two 16 ohm speakers/cabs at the same time because the imp switch goes to 8 ohms when selecting 16 ohm speaker. Since I am using one 15 ohm speaker, I need to provide another 16 load for amp impedance to be right. Do I use a 15 ohm resistor, or 12 ohm to match the DC resistance of a speaker, or does this matter? Or do I plug the powersoak into the four ohm amp output and leave it set at 8 ohms? Thanks in advance any help.
ronh is offline   Reply With Quote
Old 03-26-2009, 08:02 AM   #2
Another option is Power Scaling.
http://www.powerscaling.com/
__________________
-Bryan
tbryanh is offline   Reply With Quote
Amplifier Power and Speaker Power wolfkristiansen Harp Amps 3 01-28-2009 08:39 AM
Low power twin vs. high power twin GibsonLover Theory & Design 1 10-15-2008 11:23 AM
interesting low-power beam power tube- 5686 imaradiostar Theory & Design 5 02-19-2008 09:58 PM
'65 Fender Twin NOT REISSUE Popping on Power Up and Power Down keysnleslie Maintenance, Troubleshooting & Repair 8 10-31-2007 07:32 AM
Using a High Power OPT (400W) at half power TDS Theory & Design 21 07-25-2007 06:36 PM
