Old 03-09-2009, 03:32 PM   #1
Question for Enzo on Fender Frontman 25R
Hey Enzo,
I need to replace a input jack on a Fender frontman 25R amp. The current input jack is cracked and no more good. I want to use the switchcraft input jack like the ones used on the Fender tube amps that switch the input to ground when not in use. Will this work or is there any grounding issues by using this type of jack as opposed to the plastic jacks that are not grounded to the chassis used on these little practice amps?
Thanks
Slo
Slobrain is offline   Reply With Quote
Old 03-09-2009, 03:45 PM   #2
bnwitt's Avatar
Well, I'm not enzo but .. the pcb jacks serve the same functions as the old switchcraft jacks and are indeed grounded. They are just grounded through the pcb. If you put in a normal shorting switchcraft jack, you'll need to wire the ground tab, the tip contact tab and the shorting terminal tab to the proper pcb points. I doubt having the new jack contacting ground from it's face to the chassis will cause any ground loop issues, but if it does, you could use an isolation washer to limit its ground point to the pdb pathway.
The Bassman reissue uses the old style jacks and they are grounding at their faces to the chassis and via a wire to the control ground buss on the control PCB. Works fine.
__________________
Warning! Some Electronics devices contain lethal voltages that can kill you. If you do not feel qualified to work with dangerous voltages, refer your repairs to a qualified technician. By giving you online advice, I am assuming no liability for any injury or damages you might incur through your own actions.
bnwitt is offline   Reply With Quote
Old 03-09-2009, 08:37 PM   #3
HI,
New guy here, and I am not sure if I am posting correctly, but I have a question related to a Kay 703-C amp. I found an old 2006 post that Enzo was part of about the Kay 703-C, and the chassis being hot, and what to do about it. I just got a Truetone amp (understand made by Kay) with a schematic indentical to that of the Kay 703-C. The schematic shows it has an isolation transformer. Does that mean it is 100%, safe - no shock hazard from a mic, etc? I have been reading conficting information that this might not be all the amp needs. A 3 wire power cord for one.
Thanks!
Bear
Bear1484 is offline   Reply With Quote
Fender Frontman 15r Blown Fuse Matty Maintenance, Troubleshooting & Repair 10 07-11-2009 03:23 PM
Fender Frontman popping out mad_driver2 Maintenance, Troubleshooting & Repair 1 01-21-2009 09:10 PM
Fender Frontman GHopson Maintenance, Troubleshooting & Repair 4 01-03-2009 11:52 AM
Frontman 25R Channel Switching/Footswitch Problem. dmbspook Maintenance, Troubleshooting & Repair 18 10-09-2008 02:43 AM
Fender Frontman 15R blown output dowlesm Maintenance, Troubleshooting & Repair 6 01-11-2008 05:28 AM
