| Guitar Amps General discussion about amps |
| | #1 |
| Junior Member Join Date: Mar 2009
| Attenuators vs. Overdrives: Need opinions
Hey folks - Say a guy has $200 or so and a souped-up tweed Deluxe (6V6's in fixed bias, 5V4 recto, choke, heavy-duty OT, and 2 X 12s). What is the best value for the $200 - a good attenuator or a good overdrive? I currently own a Reverend Drivetrain 2 (improved TS9) that has worked really well with my Victoria Bassman and Blackface Super Reverb, but since the Deluxe has a much stronger midrange, the mids may get a little over-bearing. Otions I've considered are either the Geek MacDaddy British Ball Breaker Overdrive or a Bad Cat Leash Attenuator. Thoughts??? |
| | #2 |
BTW: My Deluxe is WAY too loud turned up past 4 or so for most small to medium clubs. The tone on 7 or so is like God, but will get you fired.
| | #3 |
| Senior Member Join Date: Apr 2007 Location: sydney australia
sounds like you should put it back to cathode biased if you have a head (as opposed to a combo, im not saying your an idiot ), you could invest in a single possibly less sensitive speaker, and use that for lower volumes. speakers make a big difference for volume, but its often niglected. not really helpful, but they are how i would work. |
| | #4 |
What's better, adding an appetizer to dinner, or a dessert? Overdrives and attenuators are diffferent things. Really, the thing to do is try either one and buy what results in a sound you like better. Distortion is not generic, so adding a distortion pedal won;t produce the same sound as driving the piss out of the amp and then attenuating it down to a level you want. There is no better, there is only what you personally prefer.
| | #5 |
| Member Join Date: Jan 2009 Location: Austin, TX
A good Overdrive usually cost less than a good Attenuator. They do sound different. An overdrive can be switched in and out. Most attenuators cannot ( unless you build your own ). Attenuators are hard on your tubes. I do own a THD Hotplate and a homebrew Airbrake. But I have not used them in a while. The downside to most Overdrive pedals is they take away alot of sensitivity. Some are better though , a lot of my buds like the OCD or the TIM pedal. I personally use one I built that uses no Diodes for clipping just FET's overdriving FET's. If you are handy then Try the VVR from Dana Hall. easy on the tubes and sounds great. |
| | #6 |
__________________ -Bryan |
| | #7 |
| Junior Member Join Date: Mar 2009 Location: Atlanta
| pedal
Get the Hoochie mama from browntone , he is my cousin and hand builds all his pedals, they are the cats meow.Greg
| | #8 | |
| Senior Member Join Date: May 2007 Location: Silicon Valley ; USA
| Quote:
-g | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need opinions | daz | Theory & Design | 8 | 12-22-2008 06:15 AM |
| Need your opinions please. | Weldaar | Guitar Amps | 1 | 07-19-2008 10:15 PM |
| tube amp attenuators | Valvehead | Theory & Design | 3 | 05-05-2008 10:17 PM |
| Question about power attenuators. | sexafone123 | Maintenance, Troubleshooting & Repair | 0 | 10-14-2007 05:59 AM |
| lend me your opinions | caveman | Music Electronics | 4 | 03-20-2007 04:56 PM |
