Go Back   Music Electronics Forum > Amplification > Guitar Amps > Mods & Tweeks
Old 03-11-2009, 08:28 AM   #1
blackface mod to a Gibson GA-5 Reissue...
Hi. I am very new to amp tweaking and have basic knowledge which i've acquired by having bought/rented/borrowed books and videos by dave hunter and gerald weber as well as reading many online forums. I own a reissue Gibson GA5 Les Paul Junior and successfully (drained the filter caps ) and performed 2 of the trinity mods discussed in much detail on a lengthy tdpri forum. (lifting the 1M /22pf tone filter as well as the 25uf bypass cap).
http://www.thegearpage.net/board/sho...&postcount=173
i liked the mod but, given my newly acquired obsession, i figured i'd try a blackface filter mod that Gerald Weber mentioned in one of his books. a mod i realized would be easily performed in the GA5 since the circuit board is already layed out for it. i attached a picture of the components i swapped and what their current values are. basically, the mod replaces the .022 cap with a .1uf/400v (i used an orange drop .1uf/600v), it replaces the 1M resistor with a 220k 1/2 watt, and it replaces the 22pf cap with a 250pf (i used a silver mica).
well, other than a crappy soldering job (i'm getting intermittent signal...i need to resolder!) i think it sounds pretty cool! it definitely scooped the mids and added some blackface grainy highs. my questions are:
1) does anyone predict any long term problems with this mod?
2) will there be too much bass and blow my speaker? i actually haven't gone past 5 on the volume because it sounds like my amp is now much louder and may damage the 8 inch speaker. i have changed the weber sig8 (15 watts) to a jensen c8q which is rated for 25 watts.
3) will adding the 47k negative feedback resistor be advisable?
4) any other comments?
thanks so much!
luca
lookah is offline   Reply With Quote
Twin Reverb Reissue, Reverb Mod MJN Mods & Tweeks 0 12-19-2008 05:02 PM
Blackface Bassman Toast??? signalpaths Vintage Amps 9 03-21-2008 04:41 AM
Blackface Champ dpierce05 Build Your Amp 11 03-06-2008 02:08 AM
Mod for a Fender 63 Reissue Reverb Tank. straightblues Guitar Effects 5 03-29-2007 06:03 PM
Blackface Vibrolux Grubey Doo Maintenance, Troubleshooting & Repair 3 12-05-2006 04:43 AM
