| | #1 |
| Junior Member Join Date: Mar 2009
| Channel switching Marshall TSL
I have just figured out a way to use the amp control feature on the Boss GT8 (which is a simple open/close relay) with my Marshall TSL, which uses a 6 pin din plug for the footswitch. This uses a short-to-ground method for channel switching, so (looking at the back of the amp) the center pin is the ground and the top right pin is the clean channel. So basically if you short out these two pins, no matter what channel (crunch or lead) is selected, it will switch back to the clean channel. So I made up a custom cable with a 1/4" jack on one end and a 6 pin din plug (with just the center and top right pins wired) on the other end. I know, you can only switch between clean and either crunch or lead, defeating the purpose of TSL, but it's another tone option to play around with!! Now here is my question to you....... Is it ok to switch the amp like this? Will it do any damage to it? There's a lot going on inside the footswich, its all on a circuit board...... not just a simple switch!! |
| | #2 |
| Junior Member Join Date: Jan 2010
Hi, can you provide any further details (I'm no electrician) so o can have a go at building the custom lead you mentioned? I've been searching for a cheap way to control the channel on the tsl100 from boss gt pro, but until now hadn't found an answer, so thankyou. I only use the clean and crunch channels generally, getting the lead boost from the boss unit, so your solution sounds perfect! Many thanks in anticipation |
| | #3 |
Take a look here for details on the TSL footswitch jack: http://training.tcelectronic.tc/File...SL_GMajor2.pdf |
| | #4 |
| Junior Member Join Date: Feb 2010
Does this solution also apply to the GMajor 1 ?
| | #5 |
| | #6 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Channel Switching | Mark Buckingham | Theory & Design | 11 | 02-08-2009 07:48 PM |
| Marshall JCM900/4100 PS and channel switching problem | jaz10 | Maintenance, Troubleshooting & Repair | 18 | 01-26-2009 09:35 PM |
| Marshall TSL-100 Channel Switching Delay | Mullard Man | Maintenance, Troubleshooting & Repair | 0 | 12-17-2008 01:42 AM |
| Is there a channel switching amp out there that does ...? | pine | Guitar Amps | 1 | 11-05-2008 03:44 PM |
| Marshall JCM2000 TSL feedback on clean channel | Edward1971 | Maintenance, Troubleshooting & Repair | 3 | 08-16-2008 01:00 AM |
