Go Back   Music Electronics Forum > Schematic Requests
Old 03-17-2009, 07:18 PM   #1
Crate BV300H schematic??
Any one, Bueller...Bueller?
Thanks a bunch in advance.
scustom is offline   Reply With Quote
Old 03-20-2009, 07:42 PM   #2
What is the serial number? There are different models.
JustRob is offline   Reply With Quote
Old 03-21-2009, 05:00 PM   #3
SN: BWVDO9000X
Power Tube Brd:
V6 4/25/02
06a110-01
Preamp Brd:
06a109-01
My Problem is with the +10 V supply for all of the switching circuitry, LED power, etc. We were sitting at +4, there was a bad Zener just off the rectifier, replaced it and now we're sitting at +15.
While I'm sure that there are different assemblies, the schematic for any one of them would probably get me close enough to troubleshoot this down.
Thanks for helping.
Old 03-21-2009, 07:22 PM   #4
I figured I'd give the correct schematics if possible. Looks like +15 for switching is correct. What other symptoms are you experiencing?
Old 03-22-2009, 02:37 AM   #5
Thank a bunch.
I was basing my +10V on what the BV60 uses, and I have dead on -10V. Now that I know that -10v should be -15v I can troubleshoot that further also. Other symptoms are no sound, no LEDs, but other than that, everything is normal. Heaters are fine, HV is fine. Obviously, I knew that there was an issue with the vactrols but since I had no schematic, I was kind of limited to the normal tube amp checks and then tracing the switching circuit as best I could.
I'll give it a look with the schematic tomorrow and report what I find.
Thanks again.
Schematic for a Crate FXT120 HarryB Schematic Requests 4 01-25-2009 06:13 PM
Crate v100H schematic 65Fender Schematic Requests 6 01-16-2009 01:29 AM
Crate VC-50H Schematic maulertone Schematic Requests 1 01-15-2009 05:06 PM
Crate BX-2115 schematic clintronics Maintenance, Troubleshooting & Repair 1 06-16-2008 09:26 PM
Crate schematic Valvehead Maintenance, Troubleshooting & Repair 1 12-18-2007 08:40 PM
