Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Tweed Builders
Old 03-19-2009, 10:32 PM   #1
tweed princeton volume pot
Hey all,
I just bought a Mercury Magnetics Tone Clone FTPP-55 power tansformer off EBay for $55
for some reason ( haste or wishful thing) I thought I was buying a 5E3 tranny.
So what the heck I'll build a princeton! I've darn near everything else on my bench to build one including a genuine Fender speaker baffle with a 10" ceramic speaker.. logo and everything
the Fender layout I found states the Volume pot is linear.
I find this odd.
Should I use an audio taper for the volume instead?
I'm not trying to build a perfect clone, just a good playing amp.
If I can use a 1Ma pot, I have a CTS here with a push pull DPST switch.
what would be a useful feature to make out of this? maybe a bright switch or cut?
Thanks
Ray
****EDIT*****
I'll build the 5F2A circuit, no choke.
this being a Tone Clone will i end up needing to adjust the HV?
stingray_65 is offline   Reply With Quote
Old 03-20-2009, 09:47 AM   #2
Supporting Member
Audio taper will work better as a volume pot
Just build it as per the schematic, it won't matter if the plate voltage is 20V higher than the schematic
__________________
Old 05-01-2009, 05:47 PM   #3
Wink
You're going to love your 5F2A. It's a great amplifier. I've got an original 1960 tweed with cigarette burns all over it! And funny thing, a cheap little Jensen MOD 8" sounds better than an $80 alnico in there.
PremiumPlus is offline   Reply With Quote
Adapting a Tweed Princeton Cab for a 12" Speaker slohand42 Cabinetry 3 10-25-2009 09:52 PM
Anyone Built a Tweed Princeton Enclosure mitchb_199 Tweed Builders 7 07-16-2009 05:25 PM
Tone control in Tweed Princeton 5F2-A Clone cathode Build Your Amp 17 04-25-2009 01:51 AM
princeton tweed distortion brian newman Maintenance, Troubleshooting & Repair 5 04-22-2009 01:45 AM
Tweed Princeton 5F2-A build. debug The Captain Debugging Your Build 41 12-19-2007 10:26 AM
