Go Back   Music Electronics Forum > Music Electronics
Music Electronics General discussion about music electronics
Old 03-21-2009, 04:21 PM   #1
High pitched noise from my SOVTEK MIG100
I recently purchased a SOVTEK MIG100. It has 4 Groove Tube 6L6's in it that are about a year old. When the master and the volume are turned up it gets a high pitched kinda noise going, it's not feedback. I figured it was the speaker cable but it doesn't do it with my Musicman HD130 that only has a hum but it is from the 70's. This is from the late 80's or early 90's I believe. It also sounds like the sound could be louder it doesn't cut through the other instruments at band practice like it should. Any help would be appreciated. Thanks!
adamo is offline   Reply With Quote
Old 03-21-2009, 07:03 PM   #2
Quote:
Originally Posted by adamo View Post
When the master and the volume are turned up it gets a high pitched kinda noise going, it's not feedback...It also sounds like the sound could be louder it doesn't cut through the other instruments at band practice like it should.
Well, if probably is feedback. It sounds like the amp is oscillating, internal feedback. This can be caused by any number of things, a bad cap, poor wire layout, a bad tube, etc.
This could also cause the power loss, as the amp is actually spending its energy amplifying the high pitch squeal, robbing power from the audio signal amplification.
52 Bill is offline   Reply With Quote
Old 10-15-2009, 07:21 AM   #3
start by replacing the preamp (12ax7) tube(s) with known good ones, one at a time starting at the v1 position...the one closest to the input jack.
gomez63 is offline   Reply With Quote
High-pitch noise in old tube amp (oscillation?) slidincharlie (Carlo P) Maintenance, Troubleshooting & Repair 3 03-19-2009 11:20 AM
marshall VS265 - high pitched noised at high volumes littlered Maintenance, Troubleshooting & Repair 1 02-23-2009 11:10 PM
Sovtek mig100 input problem bohemoth Repair and Restoration 0 09-09-2007 02:10 AM
High-pitched piping whistle in C30 tubeswell Maintenance, Troubleshooting & Repair 8 07-23-2007 04:36 AM
High freq. noise on carlsbro 50 per111 Maintenance, Troubleshooting & Repair 0 08-14-2006 10:18 PM
