Go Back   Music Electronics Forum > Amplification > Guitar Amps > Build Your Amp > Debugging Your Build
Old 11-27-2006, 02:27 AM   #1
KMC
KMC's Avatar
5f2-a build High pitch squeal
My 5f2-A has a high pitch squeal on start up (Much the way you would get when you have to swap the plate wires on a amp w/t NFB) Since there is only one plate wire,I'm very confused? I've double checked my wiring, All looks good.My guess is it's a grounding problem? or a defective OT? Thanks in advance for any help.
KMC is offline   Reply With Quote
Old 11-27-2006, 03:14 AM   #2
Quote:
Try swapping the anode and B+ primary wires on the OT anyway. One of the first tweed 5F2-A Princeton clones I built did this. I hooked up the wires according to the conventional wire color code, but the blue and red wires were switched.
steve
steve is offline   Reply With Quote
Old 11-27-2006, 04:41 AM   #3
KMC
KMC's Avatar
Thanks Steve! That did it.
Seymour Duncan 84-40 HT too high oc disorder Maintenance, Troubleshooting & Repair 13 04-20-2008 10:12 PM
Too high plate voltage on preamp tube slidincharlie (Carlo P) Maintenance, Troubleshooting & Repair 22 10-15-2006 08:51 PM
Marshall TSL 1000 high bias voltage - help sonic_tooth Maintenance, Troubleshooting & Repair 7 10-13-2006 05:48 PM
High freq. noise on carlsbro 50 per111 Maintenance, Troubleshooting & Repair 0 08-14-2006 09:18 PM
DD-6 Schematic or high cut mod????? 7XL Guitar Effects 5 08-11-2006 03:27 PM
